Swapping Trans.
Old Sep 17, 2003 | 05:31 PM
T MAN 554's Avatar
T MAN 554
Swapping Trans.
I have an 1980 f-250 4x4 with 351M and a stock 4spd trans.
Is there a 5spd trans that would bolt in?
Thank you
Old Sep 25, 2003 | 03:50 AM
PoeticCowboy's Avatar
PoeticCowboy
The only 5spd I know of that would come close would be a 5spod alison..but dont quote me
check around a bit and look the main thing is the splines and the bolt pattern of the bell housing
Old Sep 25, 2003 | 01:21 PM
ecarter50's Avatar
ecarter50
5-speed manual trans swap
Old Sep 25, 2003 | 02:12 PM
stangboy_82's Avatar
stangboy_82
tman a zf five speed from a small block will work but I don't know about your tcase bolting up to it do some searches through the forum's for the zf tranny and you should find everything ;you need to know
Old Sep 25, 2003 | 06:23 PM
ecarter50's Avatar
ecarter50
A smallblock (302/351w) ZF trans will not fit a 351m/400. The bolt pattern is different and the bellhousing is not removable.
Old Sep 25, 2003 | 08:59 PM
stangboy_82
yea I said the wrong thing for some reason I read it as 351w I meant a zf from a 460 will fit it no prob
