Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
PTO Cables
Old May 31, 2018 | 08:11 PM
Rollene Russell's Avatar
Rollene Russell
PTO Cables
Hi, I have a 73 n750 and the dump bed does not work. We had the cable taken off so I could bring it into town to get another like it, and well it accidentally got left in the grocery store parking lot when loading groceries. Needless to st when I returned it was gone. I'm having a hell of a time going to find out what exactly it is I need and where I can get one at. Any assistance would be lovely! Thanks.
Old May 31, 2018 | 08:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rollene Russell
Hi, I have a 73 N750 and the dump bed does not work. We had the cable taken off so I could bring it into town to get another like it, and well it accidentally got left in the grocery store parking lot when loading groceries. Needless to st when I returned it was gone. I'm having a hell of a time going to find out what exactly it is I need and where I can get one at. Any assistance would be lovely! Thanks.
No such thing as an N series after 1969. Where did you find "N750" on the truck?
Look on the registration/title, the truck is registered by its specific VIN (11 digits), post what it is.
Old May 31, 2018 | 11:21 PM
85e150's Avatar
85e150
Welcome to FTE.
Your questions deserve a thread of their own.
With respect to the PTO cables, the VIN and Warranty plate info isn't going to help.
In most cases, there are two controls for a dump bed. One is to engage the PTO, and the other is to work the hydraulics to lift, hold and lower the bed.
The cable and lever or handle for the PTO are not Ford parts.
What, if anything, do you have left of the PTO control? Where was it located? Is there a second control for hydraulics?
Go ahead and post the VIN and Warranty plate info, as knowing what truck you have will help with suggestions and a solution.
Old Jun 2, 2018 | 02:14 AM
Rollene Russell
This is the info i found based on the VIN.
Old Jun 2, 2018 | 08:01 AM
NumberDummy
It ain't worth two cents!
If you don't succeed at first, try try again.
N75 = LN750 (gas).
F = 391 4V FT engine.
V = Kentucky Truck Assembly Plant.
S16975 = 1973.
Pic: 2nd entry, column right: LN series.
Old Jun 2, 2018 | 10:07 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Rollene, is your PTO dump bed air controlled over hydraulic actuation? Just this past week we had to replace a PTO like this on a dump truck. In this case, the cable was an air line, which was fine, the problem was a seal in the valve of the air control switch. Looked like this:
On the other hand, there mechanical cables for PTO like this:
The foregoing two examples are simply to illustrate how posting images can help others help you narrow down the type of PTO control system you have, so that you can find a replacement cable for it.
Tyrone_White
2004 - 2008 F150
Apr 1, 2017 11:28 AM
jjtally
Mar 12, 2013 05:11 AM
jgieswein
Jul 21, 2008 12:32 PM
Heath62
Dec 16, 2007 08:36 PM
