Old Dan VIN
Old Dec 15, 2007 | 05:36 PM
Heath62's Avatar
Heath62
Trailering
Old Dan VIN
In case anyone was wondering, Dan's VIN is as follows:
F11JK240738
I only know what LMC truck magazine has told me. Any other decriptions?
F100
4 Wheel Drive
Stepside 8 Foot Bed
223 cid
4 Speed
Caribbean Turquoise Exterior
Kansas City, MO Plant (I think)
Old Dec 15, 2007 | 07:43 PM
Customcab's Avatar
Customcab
Need rest of the vin plate data to determine axle, trans, body color & style; This info is attach to the same plate as your vin number.
Mitch
Old Dec 16, 2007 | 02:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F11JK240738 I only know what LMC truck magazine has told me. Any other descriptions?
F100
4 Wheel Drive
Stepside 8 Foot Bed
223 cid
4 Speed
F11JK240738
F11 = F100 4WD
J = 223 I-6 1V
K = Kansas City Missouri Assembly Plant
240738 = 1962 / Assembled December 1961.
lmc told you your truck is a Stepside?
A stepside is a......Chevrolet.
Flareside = Ford: The bed is narrow and has a wood floor. The bed sides are flared out at the top and the fenders are on the outside of the bed.
Styleside = Ford: The bed is smooth sided and has a steel floor.
Look on the inside of the glovebox door for the Warranty Plate (1961/62).
List all the data you find. It can ALL be decoded here on FTE.
Several FTE members can decode everything you list from the Warranty Plate...and we go by Ford Truck Parts Catalogs for the correct information, not some aftermarket VIN decoder found in a magazine.
Old Dec 16, 2007 | 11:39 AM
Heath62's Avatar
Heath62
Trailering
Actually LMC did not list the stepside. I had never heard the term flareside. It's now obvious though about the flared bed, however I called it stepside because of the step near the cab. I assume these were once used for gas cans? Thanks for the correction....oops....sorry to all the Ford owners out there. I guess that was quite a big goof. Can I be forgiven?
Old Dec 16, 2007 | 08:36 PM
Customcab's Avatar
Customcab
Heath62; did you understand my post about the remaining vin data will determine the other parts of Dan's data.
Mitch
