Need some help
Old May 30, 2018 | 05:36 PM
Elw52's Avatar
Elw52
Need some help
I have a 96 f150 4.9 and im wanting to delete the egr, what all do i meed to remove. Ive already put a cover plare over the egr and i have plugged the hole in the manifold just nit sure if i need to remove anything else. Im also going to do away withe the air pump what do i meed to remove with this one. Thanks for any help
Old Jun 1, 2018 | 05:06 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to proper forum.
Old Jun 1, 2018 | 06:38 PM
Conanski's Avatar
Conanski
So you're OK with codes and a check engine light?
Remove everything attached to the pump and plug any points where it attaches to the exhaust.
Old Jun 1, 2018 | 09:04 PM
Elw52's Avatar
Elw52
Yes I have 2 codes 1 is a cyl 5 misfire and the other code is a egr temp sensor i pulled the plugs and they r all good could be the injector
Truckdummy
Feb 24, 2019 08:07 PM
kd2dwj
Sep 4, 2018 10:41 AM
Elw52
Jun 1, 2018 05:30 PM
DPDISXR4Ti
Jun 26, 2012 10:05 PM
tb40nd
1997 - 2003 F150
13
Jul 30, 2005 10:31 PM
