Measuring back space on wheels
Old May 29, 2018 | 03:34 PM
F100supercrew's Avatar
F100supercrew
Got a 1997 Explorer rear on my 1954 Ford F-100 , best way to measure back space-- from face of hub side of rotor to edge of bed it is 5 "-- want to use 15 " x 6 " rim--- what have others with this set-up use--- any help will be appreciated how to do it-- Thanks
Old May 29, 2018 | 03:45 PM
56panelford's Avatar
56panelford
I have the same explorer differential on my 56 pickup but used 8 inch rims on back with a 4 inch back space, tire size is P255/70 R15. I put 1/4" spacers between the rim and hub to center the tire with stock fenders and have no rub issues. I have 7 inch rims up front with the same back spacing and P235/70 R15
Old May 29, 2018 | 04:03 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
There are on-line charts that help with backspacing. The below one is one I like. But as has been said before, the section width of the tires you select is of equal or more importance. Stu
Old Jun 1, 2018 | 04:39 PM
F100supercrew
back space
Thanks for your help I got it all figured out , and needed to add a wheel spacer and center it up with a stock wheel and standard back space---
HyePo57
Oct 24, 2018 08:12 PM
toby tough
1997 - 2003 F150
Sep 10, 2016 11:59 AM
oscajo
Dec 31, 2013 02:06 PM
s1rGr1nG0
Apr 4, 2013 10:05 AM
Harrier
Feb 16, 2011 05:57 AM
