6.8 that's about to die
Old 05-29-2018, 06:54 AM
Snackman2020's Avatar
Snackman2020
Snackman2020 is offline
I have an 07 E450 econoline that is most likely about to go. It has white smoke on cold starts, and is starting to use antifreeze. The dealer wants $8000 to replace it with a reman with a 2 year warranty. I keep reading horror stories about Jasper and others. Does anyone have any suggestions, ot input on other options? It is a S vin code and haven't had any luck finding a low mileage used one.
Old 05-29-2018, 07:24 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
you do not offer miles on engine.
any maintenance done.
it could be JUST a bad head gasket.. but depending on miles.. might need the heads rebuilt...
or a replacement engine.. used or reman.
Need much more information to determine choices of action.
Old 05-29-2018, 07:26 AM
Snackman2020
It has 118k miles and I have owned it for 3 years with no issues. It was previously a Uhaul truck, and it came with extensive maintenance records. Nothing major on repairs, spark plugs, cat replacement.
Old 05-29-2018, 07:29 AM
m-chan68's Avatar
m-chan68
m-chan68 is offline
You have some important decisions to ponder over. $8000 sounds very reasonable if that quote is for a Ford dealership remanufactured unit. With the installation of that would also come a very decent warranty that wouldn't be matched by any other source.
What is the mileage and overall condition of this vehicle? How much expected use are you to get out of an $8000 investment, or put in other words, how long will it take to recoup that? Those are the questions you need to ask yourself before coming to your decision.
Old 05-29-2018, 07:32 AM
Tom's Avatar
Tom
Tom is offline
Hi Snackman, welcome to FTE! Sorry you had to find us the hard way, but hopefully we can help you save some money getting this back on the road.
The E-series is a very different chassis than an F-series, and is much harder to service. I'm moving this to the Econoline forum, you'll get a bit more specific information down there. Did your dealer break down how much their labor charge is to replace the engine? $8K seems really high to me.
Old 05-29-2018, 07:41 AM
Snackman2020
I got a quote from the commercial truck center for 9400 and the other quote was from a small Ford dealer in the country. They didn't break down the pricing, but I'm sure they will if I ask.
Old 05-29-2018, 08:45 AM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Really??? What would you say is fair then? By your above statement, I will assume you are well aware of how much more work is involved to re and re an engine assembly on a van body, versus that of a truck body.
Even worse, is we are talking about an E450 with the body sealed to the box, making body removal impossible.
To the OP. I will assume you are using this vehicle for your source of income. Having said that, again how long will it take for you to recoup an $8000 expense?
Old 05-29-2018, 09:48 AM
Tom's Avatar
Tom
Tom is offline
That's why I used the phrase, "SEEMS" high to me. I recognize that service in an E-series chassis is very different, which is why I moved it down to this forum, and asked for a breakout of labor cost vs. engine cost.
I don't know what's fair, I've never done one in a van. It was just my initial impression.
Old 05-29-2018, 08:56 PM
Snackman2020
The truck is used for my business, so it is my d
source of income. It the way I am looking at it is what truck can I buy that is in excellent condition for 8k.
I got another quote from a large dealer that is an hour a a way for less than $6800. They offer discounts for businesses, so that sounds like a winner. Also has a 3 year unlimited mileage warranty.
Old 05-30-2018, 06:39 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
I suggest focus on finding the specific problem before talking too much about replacing the engine.
Could be something less major than you think. Imagine that for a minute
Old 05-30-2018, 06:43 AM
Snackman2020
What else will cause white smoke and loss of coolant. There's no leaks at all. Also uses a quart of oil between oil changes.
Old 05-31-2018, 09:19 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
mine used a quart per 1,000 miles for more than 200,000 miles (4 years).
Also recently it it started using a bit of coolant and yet it took weeks for the tiny crack on the plastic radiator tank to catch my eye.
i’m not saying you’re wrong. Just saying you’re jumping to a very extreme conclusion when it seems appropriate to dig a little bit deeper in your diagnosis.
Old 05-31-2018, 09:24 PM
Snackman2020
Going yo to get some Bar's headgasket fix. I had it at the dealer, and they said the engine misses and the Cat is bad. The cat was replaced just before I bought the truck. They also said the engine seems to have lost some power. I don't want to keep dumping money for them to say it needs a new engine. I have read many reviews that the leak fix stuff really works, especially in my situation before the gasket is very bad.
Chunkah
2004 - 2008 F150
16
07-14-2013 02:12 PM
Lonzom10
6.4L Power Stroke Diesel
06-28-2011 08:37 PM
DieselWhisperer
10-29-2008 04:34 AM
Cecil_Stringer
04-22-2008 10:50 AM
papawoodie
Car/truck Buying Advice
02-14-2006 11:30 AM
Quick Reply: 6.8 that's about to die
