2000 ranger high miles crank no start. Will start with throttle body cleaner but then dies. Inertia switch and relay switch seams to be working .any other ideas before I drop the tank? 3.0 4x4 ext
thanks for any help
Reason: Spelling
Make sure there is spark at one of the spark plug and then all you will need is fuel. Listen for the electric fuel pump when you turn on the key. If you hear that, check fuel pressure at the fuel rail.
