Brake problems
Old May 25, 2018 | 10:34 PM
racerdon's Avatar
racerdon
Brake problems
Hello all. Tonight I had my 1997 F-250 Heavy Duty at my friends farm. I went to leave, and as I was backing down the ramp, I hit the brakes, and the pedal went to the floor. I went to pump it, but didn't get any pedal. I did manage to get it home,. but it wasn't easy. Once I got it into my drive way, I checked underneath to search for any signs of a leak, but I did not find anything around any of the wheels, or any fluid dripping off of the frame as in a line blowing out, but didn't find anything there either. So I looked under the hood, and the resevoir on the master cylender had a little (less than an inch) of fluid. My question is, how do I check or test to see if the master cylender went bad?
Old May 26, 2018 | 06:12 AM
Tedster9's Avatar
Tedster9
Yikes. Well in broad terms, if it's not leaking at a wheel cylinder or (somewhere); it's the master cylinder for sure.
Old May 26, 2018 | 06:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
if there is less than one inch of fluid in the master there is a leak somewhere. chock the wheels to keep it from rolling, then fill the master cylinder and have someone step on the brake pedal while you inspect under the truck for the leak.
Old May 26, 2018 | 07:41 AM
Robert Long's Avatar
Robert Long
Could be leaking into the brake booster.
Old May 26, 2018 | 08:23 AM
tjc transport
i ain't rite
true, but that much fluid being missing will also leak out of the booster either into the engine bay, or inside the cab.
Old May 26, 2018 | 06:48 PM
steveamann's Avatar
steveamann
When it happened to me is was the master cylinder. No brakes at all.
justinglory
Apr 27, 2017 10:58 AM
Eddillard79
Nov 24, 2014 07:13 AM
xltlariat87
Jan 21, 2009 07:05 PM
flyhound
Jan 21, 2007 02:42 PM
TXF250
Aug 10, 2004 04:07 AM
