Help! What year is this?
Old 05-25-2018, 09:26 PM
McNair's Avatar
McNair
McNair is offline
The previous owner told me it was a 1967. The title claims 1967. The PO remembers an engine swap in 1969. The tag on the motor claims a 330 from '69.
This is the VIN, which states a 330HD motor from the factory... but what is the year of manufacture of the truck? F60DRB48175
What this boils down to is the oil dipstick indicates 3 quarts too high when I change the oil and filter and put in 9 quarts. Was there an oil capacity difference between the 330MD and 330HD engines?
Or is it more likely I have the wrong dipstick?
The PO claims it takes 6 quarts. Is that the FE engine capacity?
I'll need more information to determine WHAT 330 engine it is, FE, FTHD, FTMD...
But something is seriously amiss.
Old 05-25-2018, 10:24 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
F60 = F600 (gas).
D = 330 2V H/D FT engine.
R = San Jose CA Assembly Plant.
B48175 = 1967.
C4TZ-6750-C .. 330 2V M/D / 330 2V H/D / 361 2V / 391 4V FT Engine Oil Dipstick / Obsolete
23.22" shield to full; 24.23" shield to add; 25.95" shield to end.
1964/69 all except Tilt Cab; 1970 F500/750 before serial number E50,001.
Old 05-25-2018, 10:27 PM
McNair's Avatar
McNair
McNair is offline
So it IS a 1967 truck. I thank you! That gets THAT out of the way.
Now I will deal with WHAT engine they put in it.
But it was the same dipstick for HD versus MD. Hmmm...
Old 05-25-2018, 10:33 PM
NumberDummy
I had to sign off, had a minor computer problem, so I couldn't type the following:
All 1964/78 FT's used the same oil pan except 1971/78 F600 4WD
Look on the dipstick for its stamped ID engineering number, post what it is. Number will include 6750.
Old 05-26-2018, 07:03 PM
McNair's Avatar
McNair
McNair is offline
The dipstick has no numbers.
But the measurements you give are exactly what I have when measured from the very "top" of the shield (where it would contact the tube).
Old 05-26-2018, 07:29 PM
McNair's Avatar
McNair
McNair is offline
And where are the engineering numbers on the harmonic balancer (I ran into your thread from 2012 telling a user that a positive way to ID a 330MD versus a 330HD was to get that balancer number)?
I looked on the ring face with a mirror (this truck has AC and an extra pulley extended off the balancer, so you can't see much), the rear of the balancer where the balancing cuts are, and, of course the circumference where the timing marks are. I cound't find anything but timing marks.
Old 05-26-2018, 07:41 PM
NumberDummy
C4TZ-6312-A .. 330 2V H/D/361 2V/391 4V Double Sheave Harmonic Balancer - Marked: C4TE-6316-A / Obsolete
C4TZ-6312-F .. 330 2V M/D Double Sheave Harmonic Balancer - Marked: C4TE-6316-H or J / Obsolete
I don't recall where the mark is, but if this is an auto parts store replacement, it will not be marked w/a Ford ID engineering number.
Old 05-26-2018, 07:45 PM
McNair's Avatar
McNair
McNair is offline
I found a photograph of one. Numbers on the face where, of course, I can't see them. HAAA!
Old 05-26-2018, 07:56 PM
McNair's Avatar
McNair
McNair is offline
I'll remove the extended sheave tomorrow and see what I can see. I thank you for the time you put into this!
Old 05-26-2018, 08:03 PM
McNair's Avatar
McNair
McNair is offline
And I'm beginning to wonder what engine this is at all. The PO had no idea... you saw the VIN... and even though there is a 330 tag under the distributor, the dipstick quandary makes me wonder if any of it is correct.
All I know is it's a rather large 8 cylinder Ford engine! HAA!
Old 05-26-2018, 10:00 PM
McNair's Avatar
McNair
McNair is offline
Or could it be that somebody put the wrong oil pan on it? It's the correct dipstick by your measurements. And it DOES seem to be an FT motor because it mounts to the crossmember on the timing cover.
Why is the 330 engine surrounded by so much insanity?
I'll check the casting numbers of the balancer and the crank dimension under that. Then I'll have to figure out why the correct dipstick indicates wrongly. It's either an FE motor, or the wrong pan. Or it could be space aliens.
Old 05-27-2018, 03:24 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Just blame the Russians, everyone else does.
Old 05-27-2018, 10:01 PM
Thipdar's Avatar
Thipdar
Thipdar is offline
I'd blame those Red Lectroids from Planet 10 *nodding*
mlacy
Large Truck
08-26-2015 04:42 AM
mlacy
08-23-2015 03:31 AM
81f100custom
02-18-2010 09:21 AM
fordnut forever
05-22-2009 05:16 PM
BUZZer67
11-14-2007 09:49 AM
Quick Reply: Help! What year is this?
