2006 side door outside handle doesn't work
Old May 24, 2018 | 12:21 PM
VannerDude's Avatar
VannerDude
EDIT: Just skip to last post for solution.
Can anyone post a link to the definitive dyi repair video of instructions for the darn stuck Ford door? My 2006 work van side handle won't function outside. Thanks in advance. I'd hang out but I'm now an hour late to my first customer......
Old May 26, 2018 | 09:00 AM
jimbomitch's Avatar
jimbomitch
More than likely your problem is related to this thread: https://www.ford-trucks.com/forums/2...wont-open.html
The cable retainer is plastic that crumbles with age.
Old May 26, 2018 | 07:14 PM
Im50fast's Avatar
Im50fast
Sliding door? I have a suggestion if so
Old May 31, 2018 | 11:30 AM
VannerDude's Avatar
VannerDude
Thanks for taking the time to answer. I am slammed at work, and I am installing a tile backsplash 16" up the wall in our kitchen at the same time. But having to open the front passenger door and reach in is a pain in the nether regions!
I did check out the plastic cable end sleeves and they are in place and appear fine. This is not a slider, it has the double door.
I was at the locksmith's replacing keys for my other truck my son bent, and he looked in and said it looks like something is missing between two bars (levers). So today I'm going to crimp a lead fishing weight that has a rubber insert you can attach to a fishing line. (Can't remember the name). But if I pull the rubber out I should be able to squeeze it on between the levers
I will report back..
Old May 31, 2018 | 05:20 PM
VannerDude's Avatar
VannerDude
Son of a...... just typed a few paragraphs about having no luck. Cable ends are good, sleeve things every one talks about replacing are good, I put a spacer that did nothing, and now the electric actuator rod fell out. I can't twist it around enough to get it back on.
Old Oct 17, 2018 | 09:02 PM
VannerDude's Avatar
VannerDude
OK, I finally got fed up enough I called my retired body shop buddy to help today. So here's how it went:
1) Pulled latch. Couldn't access.
2) Drilled out electric bracket rivet.
3) Confirmed cable ends were good.
4) Reinstalled cable, riveted in. DID NOT WORK.
Attempt #2
1) Completely diassembled, drilled out rivet again. Removed keyhole assembly/clip.
2) Put on cable out of another junkyard door. Re-riveted. DID NOT WORK.
Attempt #3. Pay attention now !!!!!
1) Attached a narrow vice grip to cable ball on lower end and stretched it out. Crimped on a small rubbercore fishing lead weight.
2) Let loose. WORKS !!!!!!!! Cables stretching out is apparently a SECOND issue when the issue isn't crumbling rubber ends.
Old Oct 20, 2018 | 09:20 AM
F350 1990's Avatar
F350 1990
Attempt #2
Having done about 100 or so of these in my shops (on fleet contracts) ---- for future reference, that "drilled out electric bracket rivet" is an unnecessary step ---- if you're referring to the power lock actuator, leave the mount alone, simply pull out on the "u" shaped retainer holding the actuator and it comes right out.......it's a "compression" type fit.
BTW -- I've NEVER seen a cable stretching issue if you use the Motorcraft (quality) parts..................sometime people try Dorman parts (different cable lengths) and that causes problems.................
Old Oct 21, 2018 | 11:36 AM
VannerDude's Avatar
VannerDude
Thanks for the info on the electric actuator bracket. I wish you had replied month's ago, lol.
I can assure you, these are not aftermarket parts and no parts were crumbling. When I added a spacer it worked. I can find no other explanation than stretching.
GavinL
Nov 21, 2018 12:51 PM
renchr56
Sep 22, 2016 03:38 PM
perpetualjon
Jun 2, 2016 05:45 AM
BocceMon
16
May 23, 2014 04:09 PM
DaniR1968
1997 - 2003 F150
Jan 24, 2011 10:40 PM
