Bounce, Bounce, Bounce...
Old May 24, 2018 | 08:50 AM
CousinCarl's Avatar
CousinCarl
A few months back, I had an issue with a slight 'shutter' in reverse - only happened while under load. Now, under load I get a VERY evident 'shutter' coming to a stop forward or in reverse. The back end bounces pretty good. The wife thinks I am ignoring it intentionally since it makes things inside bounce too
Does this sound like a sticking caliper sliding pin? I do plan to grease them this weekend.
Old May 24, 2018 | 01:50 PM
HD Rider's Avatar
HD Rider
Sounds like a warped rotor caused by stuck slide pins.
Old May 24, 2018 | 02:59 PM
Chevota_72's Avatar
Chevota_72
Possible u-joint as well. I had one go out on my truck and it was really evident when slowing down.
Old May 24, 2018 | 03:41 PM
Walleye Hunter's Avatar
Walleye Hunter
If you have an IR thermometer you can shoot the temps on the wheels after a drive, that should tell you something about what's going on with the brakes.
Old Jun 7, 2018 | 08:56 AM
CousinCarl's Avatar
CousinCarl
Thinking this may be it now. I read another member chased it down to u-joint in rear drive shaft as well.
I did grease all my slide pins and thought I cured it until last night it reared it's big ugly head coming to a stop light. Rotors looked as good as could be, so looks like a drive shaft rebuild is in my future.
Old Jun 7, 2018 | 09:56 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Those u-joints go very fast once they present for awhile. Change them all if that indeed is the problem. The bad one stresses the good ones!
Old Jun 8, 2018 | 04:41 AM
Wes444's Avatar
Wes444
Lucky dog
Afraid I'll never get that side benefit.
So did you decide to fix the problem, or keep the symptom?
FONRDAY
6.7L Power Stroke Diesel
Aug 12, 2012 11:09 PM
zerick
Mar 21, 2011 02:35 AM
f-150 on 22's
2004 - 2008 F150
Jan 30, 2009 12:17 AM
ltatkinson
Jul 26, 2008 09:21 PM
02crew
1997 - 2003 F150
16
Sep 22, 2007 10:07 PM
