fuel tank
Old Sep 19, 2003 | 07:53 PM
GR8 1's Avatar
GR8 1
Question fuel tank
My Fuel guage is only working for my rear tank, What should I do
86 ford f-250 4.9 i6 4spd
Old Sep 19, 2003 | 08:53 PM
Taynton1's Avatar
Taynton1
fuel tank
Do what I do. Fill both tanks, run the front one out first and wacth the rear OR get ready to spend a lot of money.
MT
Old Oct 9, 2003 | 08:50 PM
chrstnsn's Avatar
chrstnsn
No, no, no. very simple.... check that voltage is going thru the Dark Blue/Yellow wire from the front tank. First check at the connection back by the tank for a rusty, corroded, dirty, or loose connection. If no voltage is coming from the tank, check for continuity of it and the black wire from the front tank to the connection where it meets the black wire from the rear tank. If all wires check OK for continuity but no voltage thru DB/Y, then it is the guage sending unit. Run the tank out of gas, drop the tank, and replace the sending unit. No Problemo!!
664x4drvr
May 27, 2012 02:31 PM
1969furd
2004 - 2008 F150
Apr 17, 2012 07:33 PM
felixbot
Jun 17, 2010 09:04 PM
mike L
Sep 2, 2004 08:44 AM
rrawlins
Jul 1, 2003 09:37 PM
