Head Light Problems
Old Oct 9, 2003 | 10:04 PM
Fcapw's Avatar
Fcapw
Lightbulb Head Light Problems
I just recently replaced the headlights in my 1980 f-150, but the right headlight is brighter than the left. I have replaced fuses and no fix.....The wiring is original.
How can I get the lights to be the same brightness?
Old Oct 9, 2003 | 10:19 PM
locknkey's Avatar
locknkey
Check the ground on that circuit....without the battery connected, use a multimeter, check the wiring before the connection...if you get the same resistance with each ground, its of ..if you donit, its needs to be cleaned and tighten...also make sure your getting a good connection at the lamp.
