Tachometer acting weird
Old May 23, 2018 | 11:17 PM
Spaznaut's Avatar
Spaznaut
So I was driving along the other night and noticed when sitting at a red light the tach would fluctuate and sometimes bottom out to zero. When I say fluctuate I mean from around idle speed to zero but the actual engine idle would never change. I'm not sure where the tach gets its signal from on a '95 4.0 but since the engine didn't sputter and die, I figure a loose signal wire. At any speed above idle I don't see any fluctuation yet and it doesn't do it all the time. Any clues on the cause of this?
Old May 24, 2018 | 06:59 AM
shorod's Avatar
shorod
If your 1995 uses an ignition control module, that would be my first suspect. The ICM in earlier Fords were pretty well-known for causing tachometer issues during early stages of failure.
-Rod
Old May 24, 2018 | 11:06 AM
Spaznaut's Avatar
Spaznaut
I looked up icm for the '95 and don't see anything so don't think that is where the signal comes from. I'll have to look under the hood and see if there is a coil pack.
hutch246
Oct 30, 2012 10:34 PM
Beastmaster
Dec 30, 2005 03:19 PM
spiggy769
2004 - 2008 F150
Sep 26, 2005 09:38 AM
turbo69
Jul 16, 2004 06:42 PM
fordrulz
May 2, 2004 05:50 PM
