Im not sure how you would avoid rattle...the ball mount itself will rattle in the hitch sleeve.
Currently i use a pintle hitch setup with a 2 5/16 ball mounted on it. I actually had a shop cut the bottom of the mount off because there was way more adjustment than i would ever use.
But to adjust height requires removing the four bolts.
