1978 - 1996 Big Bronco
ABS MODULE?? on 96 BB
Old Oct 20, 2005 | 07:30 AM
blue&white's Avatar
blue&white
hey alll, it has been a while since my last post, but here goes; my ABS light came on, the ABS portion of my ride completely died, and after getting the codes for it turns out the "module" is dead. i asked him how much for a new one and no S**t, he said 1400.00. Could someone tell my why car dealers think they can hose me? i am not some idiot savant that drives a ford. after looking around for this "module" on net, i a came across different names for a similar part. the prices ranges from 148 to 560 dollars! i am clueless here. any suggestions?
Old Oct 20, 2005 | 05:43 PM
Ponyracer's Avatar
Ponyracer
well I checked with my local Ford Dealership that I used to work at and they quoted me
for rear wheel abs or rabs F8TZ-2B373-JRM which is at the master cylinder $273
or for four wheel abs or just abs F4TZ-2C018-A which is under the dash $605
I hope this helps you
Old Oct 20, 2005 | 09:39 PM
bossind's Avatar
bossind
Sure its the modual? Most of the ones I worked on had a seized pump motor, water gets into it. The electric motor is easy to replace and you can get it cheap out of a junk yard. Many fords use the same motor, such as a crown vic. Wire connector may be differant but you can rewire that. You can also test your ABS pump motor by jumping it and powering it up,if it doesn't pump than its the motor. If it does than somethng else is the matter, but ussally its the motor.
Old Oct 21, 2005 | 05:07 PM
blue&white's Avatar
blue&white
50 dollar solution
i am going to replace the ecu in the front end. i found one because, it is cheaper and newer than mine
if that doesnt work then the hydralic unit is spent
Old Nov 14, 2005 | 01:15 PM
blue&white's Avatar
blue&white
abs motor done
hi all,
it would seem that the motor is bad on the hcu pump. i have a manual, which doesn't explain how to swap the electric motor. any ideas? also, does anyone know where to get a replacement motor?
thanks
chris
Old Nov 14, 2005 | 01:25 PM
bossind's Avatar
bossind
Yeah isn't it just 2 screws to remove? Been a few years sense I replaced mine
gtuttle
2004 - 2008 F150
Nov 11, 2016 04:51 PM
wreckedcarz
Escape & Escape Hybrid
Sep 19, 2016 11:10 AM
njneer1
Jul 23, 2011 10:29 PM
FordCrusherGT
Apr 4, 2008 12:42 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
