The is most likely 11 System Pass for KOEO, Separator Flash (1), then 11 System Pass for Stored Codes.
You are correct. You read the codes wrong
Given your findings and photos after this post I am VERY surprised the truck even runs.
But the 1992 uses 3 digit codes. It did run but not well at all. Caps come in tomorrow so I'll install them and hope for the best.
Might be time for cheap megasquirt cheaper than the stock eec on eBay. Lol
Ford started to transition from two to three digit codes starting in 1991. It would not be unusual for your truck to display two OR three digit codes. Based on your erroneous 331 and 33 codes, a typical mis-reading of the code flashes, I would not be surprised with your two digit codes.
i was thinking of a 4.0. what synchronises the injectors with the spark?
Profile Ignition Pickup (PIP) aka Stator. It's located inside the distributor. The computer uses that signal to fire the ignition and pulse the injectors.
i bought a new computer at pull and save here in Spokane for 15.00 and it had the latest upgrades. boy did that help a lot. thanks for clarifying the injector sequencer.
