Front diff
Old May 22, 2018 | 09:11 PM
jhinalabama's Avatar
jhinalabama
Front diff
I serviced my front diff. What a pain in the *** that was. How do you guys do it. I had to drop the steering rack to get the cover off.
Old May 23, 2018 | 06:02 AM
Dunrollin's Avatar
Dunrollin
I just watched the Ford Tech Maculoco video and followed his example. He basically only opened the fill, sucked out fluid and refilled- seems more than adequate for my needs.
Old May 24, 2018 | 07:31 PM
Mercury100's Avatar
Mercury100
Went to my drill and tap chart.
Drilled a hole in the bottom of the diff housing the same size as needed to tap hole to a 1/8 pipe threads.
Let the oil push the filings out during the drain.
Tap the hole to 1/8 pipe thread.
Install 1/8 pipe plug
Mercury100's Avatar
Mercury100
<div style="text-align:left;">Went to my drill and tap chart.<br />Drilled a hole in the bottom of the diff housing the same size as needed to tap hole to a 1/8 pipe threads.<br />Let the oil push the filings out during the drain.<br />Tap the hole to 1/8 pipe thread.<br />Install 1/8 pipe plug</div>
Old May 24, 2018 | 07:37 PM
rsylvstr's Avatar
rsylvstr
i like it. Does it matter what material the plug is?
is there room to just use a small magnetic drain plug?
Old May 24, 2018 | 07:46 PM
Mercury100's Avatar
Mercury100
The housing is aluminum.
it was very easy to tap.
You would have to look around for a 1/8 pipe plug with a magnet attached.
I just used what I had on hand
Epoxy one on?
Drill out the pipe plug a bit and then epoxy?
Old May 25, 2018 | 12:42 AM
jhinalabama
I'm going to drill and tap next time. While I had the cover off I was looking at we're the best place to drill was.
Jghake
May 4, 2019 03:14 PM
crazy96863
13
Nov 11, 2012 10:09 AM
00y01e
Apr 27, 2007 11:20 AM
Fourwheelinj1
Apr 24, 2007 11:33 PM
horsecop
Jan 24, 2004 08:30 AM
