Stumbling from stop
Old Jun 17, 2018 | 04:50 PM
Freskan6.0's Avatar
Freskan6.0
I’ll check Maf readings and post. Filter is good and minder shows green.
Old Jun 17, 2018 | 06:02 PM
Freskan6.0's Avatar
Freskan6.0
I checked the readings for the petal and acc low shows .33v, my cousin came over with his 07 and I checked my values against mine and his shows 0v. Maf reads 1.88v at idle and climbs to 3v + without load. In gear under load it’s only going to 1.88v. Don’t know what the Acc low should read.
Old Jun 17, 2018 | 08:45 PM
bismic's Avatar
bismic
Light acceleration MAF should be around 2V. Cruise should be around 2.2V. Heavy acceleration it should be 4.2V. Coast 1.7V.
Sounds like the turbo isn't performing. I know you've cleaned it, but it may not have "done the trick".
Old Jun 17, 2018 | 11:20 PM
Freskan6.0's Avatar
Freskan6.0
I really don’t think it’s the Turbo but I’ll move to it and see if I can determine if it is. Help me understand how it works exactly.
when I’m at idle my vgt reads 85%
with slight acceleration it stumbles and moves to say 68% and then climbs to 85%.
My truck when driving around the amount is 60% but coasting it moves to 85%.
under full throttle it will drop all of the way down to say mid 40’s %. Is the percentage that I’m reading just what the pcm is commanding and the Turbo doesn’t actually have to be at that point or does it follow the actual movement of it as it moves. Hopefully this makes sense. The thing is my Turbo does work and make boost so I’m wondering what isn’t working right. I’m sorry for so many questions just trying to understand how it works. Thanks for your help.
Old Jun 18, 2018 | 01:00 AM
Freskan6.0's Avatar
Freskan6.0
I just took it out for a test drive and still the same. The numbers on the Maf were right on what you said they should be. I can hear the Turbo spooling as I’m moving along and see the boost building. The only thing is when I’m at full throttle it says that the pedal is only at 78% shouldn’t it go to 100% and the lowest throttle voltage stays on.33v. Do these numbers look right to you I’ve not been able to find anything that shows what they should be.
Old Jun 18, 2018 | 02:29 AM
bismic's Avatar
bismic
Hopefully this helps
APP (Accelerator Pedal Position - %):
Key on: 0%
low idle (690 rpm): 0%
High idle (1200 rpm): 13$%
Light Accel: 18%
Cruise: 19.5%
Hard Accel: 74%
Coast: 0 %
APP1 (Accelerator Pedal Track 1 - in Volts):
Key on: 4
low idle (690 rpm): 4
High idle (1200 rpm): 3.4
APP2 (Accelerator Pedal Track 2 - in Volts):
Key on: 1.4
low idle (690 rpm): 1.4
High idle (1200 rpm): 1.9
APP3 (Accelerator Pedal Track 3 - in Volts):
Key on: 0.9
low idle (690 rpm): 0.9
High idle (1200 rpm): 1.4
Old Jun 18, 2018 | 02:36 AM
bismic's Avatar
bismic
This isn't what it should be according to the numbers I posted (from Ford manuals). Not sure I understand why you say it all looks good.
I don't see anything wrong w/ APP percentages.
As stated before, I donlt think VGT should be going to 85%.
Old Jun 18, 2018 | 09:41 AM
Freskan6.0's Avatar
Freskan6.0
Thanks for hanging with me on this Bismic. I did clean it following Diesel Tech Ron’s video. I sure miss that guy. Checked clocking out and everything. I’ll pull the Turbo later today when I get home from work and see what I see. I’ll try and post some pictures of the disassembled turbo.
Old Jun 18, 2018 | 10:05 AM
FiznUKa's Avatar
FiznUKa
When you replaced the VGT solenoid did you happen to move the brown plastic piece that covers the screen. There are small oil passages that can be blocked and will result in a stumble especially when cold. Ask me how I know.
Old Jun 18, 2018 | 01:22 PM
Freskan6.0's Avatar
Freskan6.0
No I was very careful with it, straight out of the container and inside the Turbo. It was doing it before I replaced it. The thing is if I bring idle up to 100 rpms the vgt’s go to 60%. If I’m driving slow like 20 mph and give it an easy throttle it’ll drop off back to 85% and then start working down to low 40’s%. The Vgt seems to sweep back at fourth smooth with not anything jumping around. Still driving around and watching for some signs before pulling out the Turbo later.
Old Jun 20, 2018 | 06:06 PM
Freskan6.0's Avatar
Freskan6.0
Before I pull the turbo out and look at it what would cause it to be at 85% and then drop down in percentage like it should normally and then go back to 85% at idle or coasting. I’m trying to understand. With all of my readings where they are, I just don’t understand. Is it something that a sensor is telling the computer or something mechanical with the turbo. It seems that if the turbo Vgt’s are moving that it couldn’t be stuck or what? Could the unison ring be worn and then it just slips back down into the 85% area. I hope this doesn’t sound stupid. I’m stuck on what I’m going to look for.
Old Jun 20, 2018 | 06:11 PM
bismic's Avatar
bismic
As stated above, the 85% number (VGT % duty cycle) is simply a command. No way of knowing what position the turbo inlet guide vanes are actually in.
Simply stated, the computer (PCM) is looking at things (like boost, EBP, IAT, and Mass Air Flow) and issuing a command to the VGT actuator to move the vanes (open more or close more) to produce the desired air flow.
Also, the unison ring can have spots of high wear (or high corrosion and/or carbon deposits) where it tends to stick more than other spots.
Old Jun 20, 2018 | 07:27 PM
  #28
Freskan6.0's Avatar
Freskan6.0
I understand it now, even though I cleaned it up good it could somehow be stuck in the middle of its range and it would still make boost but have a lag down low causing the bogging I’m having. I’m pulling it out and see if I can figure out something. I did some dealing with a buddy that has one off a 07 that he’s dropping off for me. It’s easy enough to try it out and see if it solves anything.
Old Jun 24, 2018 | 06:30 PM
  #29
Freskan6.0's Avatar
Freskan6.0
So After taking the turbo off and looking at the internals I came up with it’s not working right. The actuator that moves the unison ring was gummed up where the rod passed through the housing. So I’ll need to see if I can get it back to where it should be. I was lucky enough to have a buddy with a good one that gave it up. I dropped it in and everything cleared up and it’s driving great. Thanks everyone for your input it really helped me to track down my issues.
rcoolb2002
Sep 26, 2019 06:54 AM
AKHunter93
16
Mar 26, 2017 09:00 PM
Rdy2offrd88
13
Nov 10, 2014 07:17 AM
ol-blu
Jan 3, 2014 06:00 AM
bigtimebubba
Mar 31, 2009 08:56 PM
