Any transmission issues?
Old May 22, 2018 | 05:41 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Am I correct in interpreting that the F-250 and F-350 use different transmissions? Does the diesel use the same transmission in each chassis?
The real question: Have there been any transmission issues in the F-250 6.2L? Apparently it's a slightly lighter duty transmission?
Old May 22, 2018 | 05:53 AM
Buliwyf's Avatar
Buliwyf
Nope. Just the 4th gear shaking bit, but that's for the diesel transmission, and extremely rare. Transmission is good to go. Best 3/4 ton trans out there, right now.
It's a lighter duty engine, with different transmission needs than the diesel. The 6.2L is noticeably better with the G trans compared to my 2015 6.2L work truck.
Old May 22, 2018 | 08:25 AM
HRTKD's Avatar
HRTKD
There are a few guys with the gas F-250 complaining about a driveline clunk. It has yet to be determined if the problem is in the transmission or not.
xxxsherpa's Avatar
xxxsherpa
The F350 6.2 has the same trans as the diesel.
Old May 22, 2018 | 08:31 AM
Bill_The_PA's Avatar
Bill_The_PA
The Diesel and gas tranny are essentially the same transmission. I believe more shims and maybe friction plates. But both are 6r140. There is a thread with many of the TSBs for the ‘17 and some ‘18. I can recall a recall for a weak plate for the park assembly on the 17. There have been many that have a “normal ticking noise in the 6.2” and as just stated above, a fluttering/ticking/chattering noise heard in 4th or 6th that is apparently related to shift cable that is to short and causes sound transmission up into the cab. (Still waiting on a TSB)
Old May 22, 2018 | 08:50 AM
JeepPuller's Avatar
JeepPuller
This is not 100% accurate. The 250 Gas has the Torque-shift G transmission. The diesel 250 and ALL 350s have the 6R140.
Old May 22, 2018 | 09:02 AM
Bill_The_PA
that’s y I said essentially
Old May 22, 2018 | 09:06 AM
JeepPuller's Avatar
JeepPuller
touche'
Old May 22, 2018 | 09:17 AM
Bill_The_PA
touche'
not really. Thanks for your input though
Old May 22, 2018 | 09:18 AM
DSLTRK60's Avatar
DSLTRK60
The G trans is not the same as the 6r140. Completely different case, much smaller.
Old May 22, 2018 | 09:47 AM
troverman's Avatar
troverman
F-250 gas engine: 6R100, aka TorqShift-G, aka heavy-duty 6R80 F-150 transmission...itself a licensed copy of a German-made ZF6HP26 automatic transmission used in many vehicles with an excellent reputation.
F-250 diesel, F350 gas or diesel, F-450, F-550, F-650, F-750: 6R140, aka TorqShift 6. There are some variations in this transmission when used in a 350 gas truck, or a 650 / 750 truck.
Is is possible it just seems that way because your 2017 engine makes 25lb-ft more torque and at 700RPM sooner, and in a lighter truck when compared to your 2015 work truck?
Old May 22, 2018 | 09:59 AM
Buliwyf's Avatar
Buliwyf
Possibly. But it's more like an F150 shift strategy than the '15 F350. (when not in tow/haul mode)
Old May 22, 2018 | 11:23 AM
Bill_The_PA
Ok. I guess I’m way off here and apologizing in advance but aren’t we talking about the ‘17-‘18 SDs (6.2 & 6.7) and they have the 6r140? They just shift different with the diesels having more shims and friction plates? Your saying that the gas doesn’t. The 6.7 250-350 have the same Powertrain and only differ in suspension slightly bigger diff housing and bigger bed blocks??
Old May 22, 2018 | 11:56 AM
Clubwagon's Avatar
Clubwagon
The 17+ F250 6.2 has the Torqshift G. The 17+ F250 6.7 and all F350s (both the 6.2 and 6.7), have the 6R140.
Old May 22, 2018 | 01:02 PM
troverman's Avatar
troverman
I need to drive one when I get a chance just because I'm curious. The first 2017 I drove was a regular cab 6.2L but it was a 350, so it had the other trans. Oddly it didn't start well or even run that smoothly and the body panels didn't line up well, but it was a super-early build. I actually thought about buying it for a work truck; it was an XLT so nicer than I needed for its purpose.
