Ok. I guess I’m way off here and apologizing in advance but aren’t we talking about the ‘17-‘18 SDs (6.2 & 6.7) and they have the 6r140? They just shift different with the diesels having more shims and friction plates? Your saying that the gas doesn’t. The 6.7 250-350 have the same Powertrain and only differ in suspension slightly bigger diff housing and bigger bed blocks??
2017+ 6.2 F250 transmission is essentially a beefed up 6r80 that was found in the F150's before the 10 speed. Completely different transmission than the 6r140. Obviously we don't know how well the 6r100 will hold up, but for me on paper it makes way more sense.
The 17+ F250 6.2 has the Torqshift G. The 17+ F250 6.7 and all F350s (both the 6.2 and 6.7), have the 6R140.
think that’s where I was going wrong. As I have the 350 most of my information gathering and readings where WRT 350s. The 6.2 has less shims and I think friction plates vs the 6.7.
Thankx all for clearing that up.
Not sure what you mean by "shims" in this respect. The TorqShift G and 6R140 are completely different transmissions. The specifics have been noted previously in the thread.
I haven't bothered to note the differences in the plate counts in the two unit's clutch packs. Not really relevant given they are completely different transmissions and not a variation of the same basic design.
He's saying the F350 with the 6.2 has less clutch packs vs the 6.7. But he didn't realize the F250 with the 6.2 now has a different transmission. At least that is what I believe he is saying.
I was referring to the friction and separator (shims) plates. Mainly the forward and direct clutch packs. 5 vs 3 and 5 vs 4 respectively.
I don’t won’t to get mired down in this as I’m not a mechanic nor a transmission expert. I’ve apologized for any confusion on my part and that My thought process and comments were based on the ‘17-18 F350 gas and diesel and mistakenly didn’t realize that until later on.
I was hoping the op (and others would focus more on the the issues that I and others have had) and that I briefly commented on. Oh well life in the shark tank right.
Hopefully this clears up the “shims” issue as this is the slang we use. Just thought folks would know what is in between the friction plates. Again apologies.
Bill.
Bill.
No problem. Just didn't know what you were referring to as "shims". In the transmission business (I am a former Aamco owner) we call them "clutches and steels". Shims are often used to set preloads on tapered bearings or to set stack heights on gearsets.
Thanks for clearing that up guys. I thought I had read that there would be different transmissions. So after a year in production it seems that there are no serious issues if any at all, that's a good thing.
The 6R80 in the F-150's is a tad quirky in it's shifting strategy but otherwise a bulletproof transmission.
