What I don't get is...with the thermostatically controlled transmission cooling being so effective, why does it take so long after the engine appears to hit operating temp for the trans to also hit operating temp?
Maybe it's due to sensor location? Or?
Engines heat up faster because things burn inside the engine. You get a lot of heat from burning fuel. Nothing is supposed to be burning inside a transmission.
I get that. The engine coolant temp sensor is likely located in the engine coolant path itself...correct? Is the trans temp sensor also located in the transmission fluid path or is it sensing something on the body of the trans itself? If it's in the trans fluid path, I'd think that it could show show a quicker warm-up.
The engine sensor is in the coolant path. The trans sensor is in the pan, tied to the solenoid body.
The transmission software needs to know the transmission average temperature, not the hottest temperature.
Just for the sake of perspective, what's the hottest you've seen outgoing fluid to the cooler in a transmission that's still operating within the normal temperature range?
