Sponsored by: Auxito
Horn not working
Old May 21, 2018 | 11:13 AM
Christen33's Avatar
Christen33
Horn not working
Single mom, don't know much about fixing cars so go easy lol. Horn wasn't working when I got the truck a few months ago, but I'd like it to. Can't afford to take it in anywhere right now so want to attempt to fix myself. When I hit the horn, the only noise I hear is a low clicking type noise. Any idea if it's simply the fuse or is it dead? Any help would be appreciated!
Old May 22, 2018 | 04:24 PM
Bluegrass 7's Avatar
Bluegrass 7
It's not a fuse if you hear a response to the Horn switch.
It's not the Clock spring in the steering wheel.
What's left is a relay and the Horn.
The Relay should be less than $5. Rock Auto pricing.
The horn about $15 to $20. Rock Auto Pricing.
Both these parts use push on wire connections.
Start at the Horn connections to see if voltage is there when then steering wheel center is pushed.
If yes, the Horn likely needs to be replaced.
It's your logic decision as you see the condition.
Good luck.
Old May 23, 2018 | 08:14 PM
Christen33's Avatar
Christen33
Tried the fuse and the relay with no luck. I'l see if I can figure out how to put in a new horn soon. Thanks so much for the help!
stanfil82
Apr 30, 2014 02:02 PM
Snapper3
Nov 9, 2012 03:42 PM
bunklash
Electrical Systems/Wiring
Mar 11, 2009 08:10 PM
martyhenry
1978 - 1996 Big Bronco
Jul 11, 2004 09:52 PM
cobraguy
Apr 21, 2002 12:57 PM
