Hardshift
Old May 20, 2018 | 02:16 PM
Joseph Addison's Avatar
Joseph Addison
Hardshift
I have a 1993 F-150 XLT 5.0 4wd it's an E4OD. Anywho. It shifts manually but if you just leave it in OD it revs real high then shifts hard I've already changed the rear differential speed sensor, change the Trans control solenoid when I changed the fluid and filter. I'm thinking its the overdrive cancel switch? Thoughts? Thanks in advance
Old May 20, 2018 | 02:54 PM
subford's Avatar
subford
Does the speedometer work right?
Does the ABS light on in the cluster?
Does light on the end of the stalk blink (OD lamp)?
Old May 20, 2018 | 03:33 PM
Joseph Addison
The abs light is on
Old May 20, 2018 | 03:35 PM
Joseph Addison
Speedometer works right as far as I know I'm just trying to figure out if I just need a new transmission or what while I have the funds
Old May 20, 2018 | 03:38 PM
subford's Avatar
subford
It would not be the OD switch then.
You will have to fix the ASB light being on before your problem will be solved.
Maybe wiring under the truck, the VSS plug, the modules or the rear end itself.
In other word you will have hard shifting until the PSOM gets a good signal from the rear end sensor.
Old May 20, 2018 | 05:27 PM
Joseph Addison
Let me ask you this motor has 290,000 .miles on it but cranks one turn no problem think I should just get a rebuilt transmission? Like I said 4wd works fine but it shifts hard in 1st and second if you start in OD in 2wd but if you Start in 1st in **** up manually it shifts fine
Old May 20, 2018 | 06:28 PM
subford's Avatar
subford
You need to check the stored codes to see if you have a VSS input to the PCM error code first.
Old May 20, 2018 | 06:30 PM
Joseph Addison
Ok do I need a special tester or can I use my obd 1 reader because I put it to the motor and I didn't get any codes
Old May 20, 2018 | 06:32 PM
Joseph Addison
Ok so where exactly is the vss? I'm sorry I'm a first time for owner
Old May 20, 2018 | 06:42 PM
subford's Avatar
subford
An OBD1 reader will work.
VSS: Vehicle Speed Sensor.
But in 1993 it was called the DSS.
DSS: Differential Speed Sensor.
If the speed information from the PSOM to the PCM Computer is bad you will get a VSS error.
Attachment 277289
Old May 20, 2018 | 06:44 PM
Joseph Addison
If that mounts on the rear end I've already changed that how do I check the stored codes?
Old May 20, 2018 | 06:58 PM
subford's Avatar
subford
To check for stored codes sometime called CM codes you run the KOEO self-test and when the KOEO electrical test is done you let the test continue and you will get a separator pulse and then the CM stored codes will read out. See diagram below.
CM: Continuous Memory.
Attachment 284728
jimandjimmer
Sep 12, 2009 07:23 AM
Revolution
1983 - 2012 Ranger & B-Series
Apr 23, 2009 09:11 PM
MTMike
Sep 19, 2005 01:40 PM
F0rdF0rever
Nov 15, 2003 11:22 AM
KM0L2002
Oct 18, 2003 05:44 AM
