are the front door bottom hinge bushings replaceable?
If so anyone have a source for the bushings?
i either have to slam the doors or lift up a bit to close them.
watching the hinges while lifting up on the back of the door I can see all the play is in the lower hinge... looks like the pin will push up from the bottom.
