dipstick y block
Old May 17, 2018 | 09:29 AM
gatorjaws's Avatar
gatorjaws
dipstick y block
.hello, I have a 1963 f250 4x4 and i am not sure if i have the right dipstick. the manual says some take 7 qts and some take 6.From what i can tell i have the larger pan but with 7 qts in it it goes way over the marks.my pan definitly has the profile of the 7 qt pan. thoughts?looking at the pictures of both pans mine look like the 7.
Old May 17, 2018 | 09:58 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Lots of threads to read, but here's one example.
https://www.ford-trucks.com/forums/1...-dipstick.html
Chad
Old May 17, 2018 | 10:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by gatorjaws
.hello, I have a 1963 F250 4x4 and I am not sure if I have the right dipstick.
The manual says some take 7 qts and some take 6. From what I can tell I have the larger pan, but with 7 qts in it it goes way over the marks.my pan.
Definitely has the profile of the 7 qt pan.
I doubt the pan is 7 quarts, when you consider there's no specific 4WD pan or dipstick.
C0TE-6675-A .. Oil Pan / Obsolete
1957/59 F100/700 272/292; 1960 F100/350 292; 1961/64 F100/250 292.
C1TE-6750-C .. Engine Oil Dipstick / 25.50" from shield to end; 24.50" from shield to add; 23.54" from shield to full / Obsolete
1961/64 F100/250 292 except w/Ram's Horn exhaust manifolds.
C1TE-6754-B .. Engine Oil Dipstick Tube / Approx. 18 3/4" long / Obsolete
1961/64 F100/350 292 except with Rams Horn exhaust manifolds.
Old May 17, 2018 | 04:24 PM
charliemccraney's Avatar
charliemccraney
The truck pans are pretty easy to identify. Both rear sump. The 7 quart (Heavy Duty, not F250) has 1 drop down (2 levels) while the much more common 6 quart pan drops twice (3 levels) It's probably just a case of mismatched parts. The T-Bird pan is also rear sump and only drops down 1 time but it is much thinner at the front section, making a very noticeable drop, whereas the truck pans are more or less wedge shaped.
If you are positive of the pan capacity, then mark the level at the next oil change.
Amphihauler
Mar 21, 2018 02:29 PM
kooper909
Jun 27, 2007 02:59 AM
ranch67
Mar 19, 2007 06:43 PM
Headman
Jul 31, 2004 06:56 PM
51dueller
Dec 15, 2002 12:43 PM
