61-66 Conventional Cab Inner Cab Corner Pics?
61-66 Conventional Cab Inner Cab Corner Pics (body code 81)
I'm doing some recon into what it might take to get these (AFAIK currently unavailable) parts re-popped, but had no luck finding any clear pics of them.
Does anyone have any decent pics? (or has a sold truck to take pics of)
Can anyone confirm that the LH & RH inners are mirror images or each other? (and if not, what are the differences side to side??
I have a lacy one here I cut out of a 66 Custom Cab donor truck. I'm going to dill out the spot welds and remove the remnants of the other panels that are still attached to it, then have it 3D scanned..... that's only step one in a journey that will take quite some time.....
Thanks in Advance
James
Thanks in Advance
James
Brad: I have a pic that should explain what/where the inner cab corner is, but basically, it is the panel in front of the cab corner. The cab corner being the lower bottom portion behind the door, which pretty much everyone who isn't from CA, AZ, NM, OR has to repair
The pic has two rectangles (done in Paint), the one to the left of the pic shows the outer cab corner, the one to the right of pic shows the INNER cab corner....
I have a pic which I will put it in my Album.
https://www.ford-trucks.com/g/picture/9777143
HTH
Cheers!
James
HTH
Cheers!
James
78 PEB
05-03-2011 07:10 AM
