RKE module part number help?
Old May 16, 2018 | 08:51 PM
Teutonics's Avatar
Teutonics
I'm embarrassed to ask, but for the life of me I cannot find this part number... I need the # for a 2006 E-350 XLT 5.4L - Remote Keyless Entry module. I've tried parts.ford.com, Rockauto, Advance, NAPA, and google every which way I can think of. No luck. Can anyone point me to a source to find this part number? TIA!
Old May 16, 2018 | 10:50 PM
annaleigh's Avatar
annaleigh
I would double check with NumberDummy
I found two different numbers. My guess would be the K but I found no definite info on the part numbers.F3AZ-19A361-K
andF3AZ-19A361-G
Here is some instructions for programing a remote for a 2006 econoline
https://northcoastkeyless.com/2006-f...-instructions/
Old May 16, 2018 | 11:17 PM
annaleigh's Avatar
annaleigh
OOPS,,, Might be this one.. This is called anti theft control module though.4C2Z-15604-AB
https://www.partsmaven.com/ford/oem-...Y4LWdhcw%3D%3D
Old May 17, 2018 | 12:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by annaleigh
I would double check with NumberDummy.
I cannot help-see below.
and F3AZ-19A361-G
I don't have a parts catalog after 2001.
I typed " remote keyless entry module " into autonationfordwhitebearlake.com online parts catalog, two different part numbers came up, neither are yours.
EDIT: One is 4C2Z-15604-AB .. Control Module aka Alarm/Keyless Lock System ~ MSRP: $242.71 // autonationfordwhitebearlake.com online price: $186.89
Old May 17, 2018 | 06:54 AM
Teutonics's Avatar
Teutonics
Thanks all!
Old Jun 16, 2018 | 07:33 PM
Teutonics's Avatar
Teutonics
Follow up tip: Pull and reinsert all of the fuses for the RKE and door lock circuits. Either removing power can “reboot” the module (otherwise it has constant power), or reseating the fuse closes a broken (corroded) connection at the fuse.
And I thought I had to buy a new RKE module!
Old May 20, 2025 | 08:30 PM
RobbieDobbie's Avatar
RobbieDobbie
1st Gear
I know this is an old thread but I believe we have the same van down to the color, and I'm having this same issue right now. I will be trying this solution tomorrow.
Nicklatech
Apr 17, 2019 07:02 PM
geta4x4
Apr 19, 2009 03:50 PM
chemisti
1997 - 2003 F150
Feb 13, 2000 10:55 AM
