Strange AC compressor buzz/grind issue
Old May 16, 2018 | 05:53 PM
Vertigo RT's Avatar
Vertigo RT
Hey, all!
as the temperatures here in florida continue to clime, as they do... Ive noticed a stange issue with my air conditioning.
It started off simply NOT cooling at idle, the air wouldnt be HOT, but ambient at best... I read a little and someone mentioned the clutch fan is inefficient and to install a pair of Mk VIII efans.
Ordered these and while waiting, decided to just do some checks on everything else. With a gauge on the low side piping Im getting about 45psi from the ac line. Seems nominal. The compressor appears to be engaging wheb the AC or “auto” button is used on the HVAC controls. Again though, NO cool air at idle, though it cools nicely while moving.
I did notice though, while in park, if you bring the RPMs up to ANYTHING beyond idle (such as 1200rpm) the compressor will spin and buzz LOUDLY (like a gameshow buzzer) for about a second and then disengage. This occurs about once every 3 seconds, continuously, on and off with the buzzing occuring whenever the compressor engages, and almost immediatly shutting off. My condensor and evap are both new. All else seems factory.
Any thoughts here? Is it an air gap thing? Theres no pings or other sounds at all... just that nasty sounding buzz, almost a grind sound.
Thank you!
Old May 16, 2018 | 06:00 PM
Vertigo RT's Avatar
Vertigo RT
Forgot to mention
2008 Lincoln Mk LT
Old May 17, 2018 | 12:53 PM
1saxman's Avatar
1saxman
Low refrigerant charge most likely. Sounds like the compressor is rattling also which might indicate its shot.
Old Sep 13, 2019 | 09:26 AM
Onemoreblessedtexan's Avatar
Onemoreblessedtexan
Any recommendations on a replacement ac compressor choice?
Old Sep 13, 2019 | 02:41 PM
Rumble phish's Avatar
Rumble phish
Get a rebuilt or new Motorcraft. Don't skimp on it. I did, and I regret it now. Mine works okay, but not nearly as good a stock unit.
Old Sep 13, 2019 | 04:48 PM
Onemoreblessedtexan
Motorcraft YCC355 A/C Compressor Assembly
Amazon Amazon
By chance would You know where I can find some legit motorcraft injectors? I wonder if Rock Auto sends good parts? I have never used them but my injector 7C3E-9F593-AB, 7C3Z9F593A or motorcraft CM5144 is a beast to locate.
Old Sep 13, 2019 | 06:47 PM
Beechkid's Avatar
Beechkid
Motorcraft YCC355 A/C Compressor Assembly https://www.amazon.com/dp/B00HFLDXQU..._r2aFDbB98E3Y0
That's where I get mine...………………..
Old Sep 13, 2019 | 07:26 PM
Onemoreblessedtexan
Thank You Beechkid. Only place I can get a new set for decent price. Best to not be remains. Oddest thing is my old injectors have 08 on them. I think they were original with 280,000 miles quick question I can't seem to get my head wrapped around is what's the best solvent and method to clean the carbon off my air intake upper poly plastic manifold?
Old Sep 13, 2019 | 11:39 PM
Rumble phish
Amazon
Got my injectors from Amazon. Best price by far, genuine Motorcraft.
I also got my new intake manifold on Amazon. Same deal, genuine Motorcraft, best price shipped to my house.
Old Sep 14, 2019 | 12:17 PM
Beechkid's Avatar
Beechkid
Thank You Beechkid. quick question I can't seem to get my head wrapped around is what's the best solvent and method to clean the carbon off my air intake upper poly plastic manifold?
You're sooo welcome BTW.....
The intake should be relatively clean....so any intake spray cleaner and a rag should work well for you.
Old Oct 8, 2019 | 08:02 AM
Onemoreblessedtexan
My intake was toast! I disassembled the butterfly valves and soaked the metal in Chem-Dip over night. Used soap and warm water for all the plastics.
Old Oct 8, 2019 | 12:45 PM
Beechkid's Avatar
Beechkid
Looks like you're ready to go!!!!!!!!!!!!!!!!!!!
natedog37
15
Sep 26, 2017 11:00 PM
hardeyf150
2009 - 2014 F150
Mar 13, 2017 06:39 PM
IHbase
Jul 24, 2015 07:37 AM
Saxon
May 26, 2007 08:29 AM
Buggie
Sep 25, 2004 07:52 PM
