compressor not turning on (getting power)
Old May 16, 2018 | 01:08 PM
llh's Avatar
llh
The air blows but the compressor does nothing. This is a 2006 ford f150 lariat 5.4. does anyone know where to start for fuses or relays? stopped suddenly, before that was operating ok.
Old May 20, 2018 | 04:40 PM
alloro's Avatar
alloro
If you're getting 12v at the compressor pigtail then the compressor clutch coil is fried or the air gap is too great.
Old May 20, 2018 | 08:01 PM
llh's Avatar
llh
more info
I also had a bad miss come in at the same time it stopped working. it has been suggested that the pcm could have turned the ac off? does anyone know how to test for that? I have c odes po351 and po430. I had the cat code for awhile. this all happened suddenly when I was making a rather sudden stop.
Old May 21, 2018 | 08:52 AM
alloro's Avatar
alloro
Yes the PCM will turn off the compressor when the engine is misfiring over a certain level, or if the engine temperature is too high.
Dan Purcell
May 5, 2015 03:14 PM
jimbo beam
Dec 12, 2009 05:17 AM
IZZYAZ
Apr 10, 2009 10:46 PM
Alby
Apr 5, 2005 09:53 PM
fcarruth
1978 - 1996 Big Bronco
Jul 19, 2003 01:12 AM
