2006 E350 Blower Motor Issue
Old May 15, 2018 | 04:47 PM
thecorvetteben's Avatar
thecorvetteben
Exclamation 2006 E350 Blower Motor Issue
Chasing my tail when it comes to the blower motor. I have narrowed it down to the fact that I do not have power to the left side of the blower motor relay (Pin 85).When I jumper the pin (simulate a working blower motor relay) the blower will work on all speeds like it should. I have included a screen shot of the manual which I have used to chase down the issue so far. It has led me to the words "repair circuit 296" but I cannot for the life of me figure out where in the book it says how to do that. HOW DO YOU REPAIR CIRCUIT 296 from step M3?
Thanks in advance!
Old May 16, 2018 | 07:20 AM
projectSHO89's Avatar
projectSHO89
The factory service manual makes the assumption that it is being used by a trained technician. A trained technician would then refer to the EVTM to locate circuit 296 in the appropriate schematic and then use standard troubleshooting techniques to identify the fault and then make necessary repairs. You won't find the level of detail you're asking about in the manual, it's assumed that you have the basic skills to perform the diagnosis and repair.
I will point out that the diagnostic procedure you seem to be using is not for the 2006 E350, it's for something else. There is no "Circuit 296" in the subject vehicle's blower motor circuit.
Old May 16, 2018 | 07:26 AM
thecorvetteben
No worries. I found the fuse box under the dash. After replacing the 15 A fuse that had blown, everything now works like it should.
Old May 16, 2018 | 11:07 AM
projectSHO89
Good deal. Glad it turned out to be something simple after all.
However, fuses don't just blow out of nowhere (except very, very rarely), something caused too much current to pass through it. Do keep an eye open.
Toneblair
Mar 5, 2016 08:36 AM
dockwatson
Mar 12, 2014 08:42 AM
captain2207
Aug 25, 2013 02:50 PM
budthedog
13
Jan 16, 2009 09:29 PM
apollo95
1983 - 2012 Ranger & B-Series
Oct 10, 2006 12:31 PM
