The long rubber piece between dash and windshield wont stay down on the ends, about the last 6" from the ends. Tried pushing the ends down with ignition key but they come backing out after a couple of days. Any ideas?
Most of the ones I've seen (mine included) are short leaving the corners exposed and lifting. I took mine to the dealer and they replaced it but then shortly after started curling up and popping out, took it back again and the mechanic noted as "replaced" but when I checked mine is invisible, must be a new part #.
