Fox 2.0 or Rancho 9000?
Thanks for all the replies. Sounds like the Ranchos are the way to go for the money and what I’m doing. I do like the Fox. Would love for them to be adjustable, but that raises the price considerably. My truck is a daily commuter that I usually am towing hauling stuff on the weekends. It will only see off-road when going down an occasional dirt road.
I've been thinking about this also. I called my local truck accessory installer and to my surprise he told me not to change out the oem shocks on my 2018 F250. He said it won't make a lot of difference. He did say that adding a steering stabilizer will. For the ones that are getting ready to switch out please keep us updated.
I have run the 9000s on my 08 250 and the ride improved significantly. I installed the Foxs on my 17 since i had already installed dual Fox Stabilizers and i wanted to keep everything the same. The ride seemed to improve quite a bit over the factory crapos that came with the truck. I wouldnt hesitate to run the Ranchos again in the future especially since they cost a bit less than the Foxs. I will say that the adjustment is noticeable on the ranchos. You probably wont be disappointed with either of them.
My my biggest reason for swapping shocks is that I am adding the 2.5” leveling kit so I needed longer shocks. Otherwise I would have stuck with oem, I don’t think they’re nearly as bad as everyone makes them out to be.
Thinking about swapping my OEM stuff out too. I seldom haul any trailers. I keep a 4 wheeler in the bed quite often. I do pipeline work, so I drive 1-2 hours one way every day to work on the highways, but once I get to my destination, it's a combination of neglected gravel/dirt roads with potholes that could swallow a school bus, then driving on pipeline ROW's, which depending on weather, will be rocky, muddy, up and down hills, etc. The other day, I was driving a back road at work, and there was a piece of paper on my dash that was causing a glare. I leaned forward to grab it, hit a small bump in the road and smashed my head against the steering wheel. I really wish I had it on video.
The combo of on and off road i think is what will make it tough to find the perfect thing to get the smoothest ride out of this beast. Main reason of going 3/4 ton was to have a better handling when keeping my 4 wheeler in the back for long periods of time (had it in the back from last spring until last fall everyday), plus the extra ground clearance versus my old f-150 is significant, and really comes in handy driving over the water bars on the pipeline.
Shot of both of them. Had our 66 that is in our garage across town out today also.
Front - 983-50-010
Rear - 984-50-717
To get the rears, I chose 4wd, stock height. For the front, I had to chose 0-1.5" lift.
#28
Also, not 100% related to this thread, but close... Anyone running the BDS NX2 shocks at stock height? They are considerably cheaper than Fox 2.0s or Rancho 9000's, I'm sure they may not perform quite as well, but for a pavement pounder, might be good enough for an inexpensive upgrade over stock? For the price, I can replace them in a few years and still be cheaper than the Fox 2.0s or Ranchos. Anyone have these shocks?
#29
Save that receipt.
LIMITED LIFETIME WARRANTY (limited to qualifying Rancho® products only)*
Tenneco warrants qualifying Rancho® products against defects in materials or workmanship (except finish) when used under normal operating conditions for as long as the products are installed on, and the original purchaser owns, the original vehicle on which they were installed.
[QUOTE=Pugga;18010079]Also, not 100% related to this thread, but close... Anyone running the BDS NX2 shocks at stock height? They are considerably cheaper than Fox 2.0s or Rancho 9000's, I'm sure they may not perform quite as well, but for a pavement pounder, might be good enough for an inexpensive upgrade over stock? For the price, I can replace them in a few years and still be cheaper than the Fox 2.0s or Ranchos. Anyone have these shocks?[/QUOTE]
