Fox 2.0 or Rancho 9000?
#121
Not sure what you mean by secondary weld. There is not another primary weld as these two welds are the only thing that attaches the mounting ring to the shock body. I should have taken pictures before I mounted them. The welds were not the entire length of the contact area and not filled in correctly (thin string bead). The weld heat (amperage) was to low and the welder moved to fast during welding.
#122
There is a weld UNDER that one
RS9000?XL Shock Absorbers - Rancho® Performance Suspension & Shocks
Double-welded loopsAdded strength and durability
6575]Not sure what you mean by secondary weld. There is not another primary weld as these two welds are the only thing that attaches the mounting ring to the shock body. I should have taken pictures before I mounted them. The welds were not the entire length of the contact area and not filled in correctly (thin string bead). The weld heat (amperage) was to low and the welder moved to fast during welding.[/QUOTE]
#123
Great, sounds good. However, the link you provided does not show the weld "under" nor does the wording "double-welded" prove anything as there are two (double) welds visible on the exterior. Hate to be a PITA, but do you have a picture of the construction that shows the weld you are referring too?
#124
The link was provided to let you know this is what we do.
I do not have a pic of the first weld, sorry.
But as you can see from the pic above and the story the guy told us, the double welded loop holds.
I will run out and look under my vehicles and see if I one is visible.
No luck, I would have to remove the shock
And have an e-mail in, hopefully someone can get me a pic.
#125
#126
Loos like
RS5406 is the stabilizer
RS5542 is the bracket
#127
#129
#130
#131
News to the 10's of thousands that don't leak.
I would return it. We are readdressing the single setup now.
#132
Yeah, I am returning it. Of course I have to pay to ship it back. Please recommend that the Rancho website is updated so that more people don't buy the wrong product and end up losing money.
#133
In addition I got my 9000 xl's installed today as well. No issues replacing the rear shocks except both front and rear shocks are a lot more narrow where they bolt up. Fronts were a bit more difficult, especially the passenger side. Not sure what was up with the old shock on the passenger side, I got the nut loosened but then it just wouldn't come off. After trying several things, taking breaks, going back to it, the threaded rod of the shock actually snapped off allowing me to remove the shock. I set the front at 6 and rear at 4. Much, much better ride! I am very pleased with them. I also had to go pick up our new Polaris RZR so hooked up the trailer and towed it home. I'm impressed. Shocks and stabilizer are great!
#134
Front - 985-24-154
Rear - 985-24-151
CJC Offroad just got them in. Mine will arrive Tuesday and planning to install Wednesday morning.
Looks straight forward - hope I don't need to remove the front tires..... Tips anyone?
CJC had a good price on them.
#135
No tires removed. No jack or anything. Simple as getting the correct socket and open end wench for the front. I used a 21mm to remove stock front upper nut. New hardware included a 19mm (3/4") upper nut.
I pulled my Rancho branded FX4 shocks off. I liked the larger diameter stock bushings etc. in comparison to the hardware/bushings that came with the RS5000X's. Plus, one of my hardware kits was missing a bushing. So......... I decided to try and reuse the stock hardware/bushings on the new shocks........ WRONG. The are both 12M thread, but a different pitch. Fought that for a bit before I figured out the problem. The stock nut and attached bushing would not work. I went back to O'Reilly's and got another hardware/bushing kit. All is fine. The tip......... use your new hardware and check to make sure everything is there before you grab a wrench.
P.S. - I am at 25,000+ miles on the stock FX4 shocks. I've read so much here about how horrible the stock FX4 Rancho "branded" shocks are. Many reports here talk about them leaking and lack of compression strength at <1,000 miles, etc. I am certainly not disputing any of those reports. But......... none of mine had any sign of a leak and they all had some power left in them. They were a long way from limp. Granted not as stout as the new ones I put on, but they were not horrible at all.
