4R100 bypass for an E4OD
Old May 15, 2018 | 02:16 PM
HT32BSX115's Avatar
HT32BSX115
Arrow 4R100 bypass for an E4OD
Howdy all,
I apologize if this has been asked before but a search (here) didn't produce any results!
There seems to be a fair amount of people installing the 4R100 fluid bypass/check valve, fittings and 3/8" cooler lines on E4OD's.
The 4R100 (3/8" fittings) bypass seems readily available and fairly inexpensive.
I don't have a integral radiator trans cooler in my OE Radiator........(seems they didn't put auto-transmissions in 55 F-600's) So, I'll will use a stand-alone (big) DERALE remote cooler/fan with an inline filter etc.......
There's also a check valve in the return fitting of E4OD's that is there to (presumably) prevent fluid siphoning out of the TC and I assume that the 4R100 bypass & banjo fittings do the same.
Has anyone here done the 4R100 bypass and changed to 3/8 lines and fittings in an E4OD ? Is it worth doing it? (Do we really even need the bypass?) I haven't plumbed anything yet, and since I haven't even made up all the cooler lines, I can go either way.....It makes sense to use larger lines in any case......
Thanks,
Rick
Old May 17, 2018 | 02:02 AM
HT32BSX115's Avatar
HT32BSX115
Ok,
Got all the questions answered!
Thanks to all that replied!
HT32BSX115
May 24, 2018 09:59 PM
brennanforgeron
Feb 2, 2017 01:45 PM
larry1211
Oct 12, 2007 06:11 PM
JBronco
1978 - 1996 Big Bronco
Mar 17, 2005 06:42 PM
F250_E4OD_460_2WD
Sep 4, 2001 10:04 AM
