Frame
Old May 14, 2018 | 04:19 PM
5851a's Avatar
5851a
Frame
I did search but blame old eyes or crs. Is there a chart with the frame dimensions? Between F150 and a F250 of a given year is the metal thicker and C section taller? Thanks
Old May 14, 2018 | 05:31 PM
flowney's Avatar
flowney
Among the 4X2 models, the frame on an F-250 will be substantially thicker than the frame on either an F-150 or F-100.
Old May 14, 2018 | 05:45 PM
5851a's Avatar
5851a
Thank you!
Old May 14, 2018 | 06:01 PM
1320stang's Avatar
1320stang
1976 Ford Body Builder's Layout Book - FORDification.net
Old May 15, 2018 | 10:57 AM
speedfreak78's Avatar
speedfreak78
I've always heard the frames between 1/2 tons and 3/4 and 1 tons were different, not just with Ford's. I've personally measured a 78 ford 150 4x4 and 79 250 4x4 frame with calipers, and they were the same thicknesses and section height. I wanted to use the rear frame off the 150 on my 250. I've also measured 94+ dodge ram frames and they are the same, even tough everyone says the 3/4 ton+ are thicker. None of those ford dimensions linked to note any variance in thickness.
Old May 15, 2018 | 11:17 AM
flowney's Avatar
flowney
As they say, YMMV. I measured frame thickness on a '76 F-100 4X2 and a '76 F-150 4X2 and found them to be equal at 1/8" I then measured a '77 F-250 4X2 Camper Special and found the frame thickness to be much greater than the two '76s.
I was hoping to use the front frame horns of the '77 to repair frame damage on the '76 F-150 but they were larger in both thickness and height.
Old May 15, 2018 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old May 15, 2018 | 03:01 PM
fordguy76's Avatar
fordguy76
I've measure my 78 f150 and 250 (both 4x4s) and they were the same thickness and section height...at least in the back anyway.
Old May 15, 2018 | 05:01 PM
5851a's Avatar
5851a
Thanks everyone and ND, that's the chart I was thinking of. All good info though.
Old May 15, 2018 | 09:08 PM
1320stang's Avatar
1320stang
My buddy has a '85 Ramcharger, he bought a 4x4 Cummins, '91-'93 IIRC, he found the frames identical except for thuckness. He cut both frames under front seats and swapped both out, '85 Cummins Ramcharger with 3/4 suspension and an early 90's 1/2 ton flatbed with 360/727.
unilover6163
1961 - 1963 F100 Unibody
Apr 3, 2017 07:52 AM
Louislindsey72
Apr 13, 2015 12:00 PM
80f100302
Oct 8, 2005 12:19 PM
rcb
Jul 28, 2001 06:33 PM
