So how much can I really pull?
Old May 14, 2018 | 01:27 PM
HotRodTortoise's Avatar
HotRodTortoise
So I'm in the market for a toy hauler so I can take my family around south-western US for the next 6 months or so and I am trying to figure out exactly what size trailer I can really pull. I have a 4X4 2012 Ford Expedition EL Limited with the HD Tow Package. Specs claim it can pull up to 8,700 lbs but I am hearing a bunch of mixed stuff from people about what is reality. I've been looking at 32' trailers with dry weight in the 6,500-7,000 lb range and GVRW of no more than 9,000 lb (goal to stay at or below 8,500 lb max). Some of the people in the trailer FB group are claiming that the 1/4 tons can't handle it but most of them are pulling with GM and I don't know squat about their set up. So what have y'all experienced? Can the Expy really pull the advertised 8,700 lbs on a true road trip? Mine has the:
  • 5.4L SOHC V8
  • 6 speed automatic
  • 3.73 axle ratio
  • HD Tow Package
    • Transmission cooler
    • Air shocks
    • 7 pin connector
    • Class IV tow hitch
Thanks everyone!
Last edited by HotRodTortoise; May 14, 2018 at 06:29 PM. Reason: Updating features for clarification
Old May 14, 2018 | 03:30 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
What engine do you have? Reply'ers will also need what rear ratio too.
Old May 14, 2018 | 03:39 PM
HotRodTortoise
Sorry, thought I’d posted that. I have the 5.4L V8 with the 6 speed 3.73 gear ratio tranny.
Old May 15, 2018 | 08:03 PM
senix's Avatar
senix
I'd stick to around 7-8K range for the trailer GVW.
Old May 17, 2018 | 08:30 AM
CGMKCM's Avatar
CGMKCM
SUV and Van Tow Rating Reviews
Old May 17, 2018 | 11:11 AM
Clubwagon's Avatar
Clubwagon
How much the Expy is rated for and how much you actually are comfortable towing are often two completely different things.
That 8700 lbs in a 16' double axle dump trailer is probably not too bad. That same 8700 lbs in a 32' travel trailer is a very different towing experience. 32' creates a lot of inertia and aero issues compared to that little dump trailer.
Once you add wife and kids and the stuff in the Expy, the tongue weight of the trailer, the Expy will likely be over gross.
Bottom line, assuming you are within guidelines and limits, towing a 32' travel trailer with an Expy might not be a good experience, especially for an extended trip or period of time.
JetFuelBurner
21
Sep 30, 2022 09:45 PM
theoldwizard
Sep 14, 2015 07:15 AM
AkanaF150
1997 - 2003 F150
Sep 26, 2010 03:20 PM
newfieboy
Feb 22, 2009 10:56 AM
90Ford250
2004 - 2008 F150
May 11, 2007 02:11 PM
