Would you run 18 year old oil?
Old 05-11-2018, 08:03 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
I was cleaning out the old storage room at work and found a 5gal bucket of "NEW" Rotella 15w-40 Conventional most of the lettering on the bucket was gone due to some chemicals falling over the bucket but there was a date tag on the bottom of the bucket that read "00-15-10 im assuming thats the date on the bucket and contents with in.
So with the assumption that it is in fact and 18 year old batch would you run it? If I do decide on using it its most likely going to be used one of the equipment at work.
Old 05-11-2018, 08:24 PM
akcooper9's Avatar
akcooper9
akcooper9 is online now
I wouldnt run it in anything I cared about. Instead, I'd mix it with some paint thinner and paint my utility trailer decks with it
Old 05-11-2018, 08:29 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Nope I wouldn't run it in anything. The TBN is probably low and the additive package has for sure dropped out of suspension.
Old 05-11-2018, 08:34 PM
jhl3's Avatar
jhl3
jhl3 is offline
Agree with both of you.
Oil for the bar on a chainsaw....that's about it as far as a lubricant for any metal.
Old 05-11-2018, 08:35 PM
z31freakify
Interesting never new the addives would decipate with time,
Old 05-12-2018, 10:23 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
I never knew they would "drop out of suspension". I'll have to look into that. I wouldn't think there would be any issue, but I am not sure.
Old 05-12-2018, 01:48 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is online now
As long as it was sealed I'd think it is okay. Call blackstone and ask them, they'd tell you for sure. They could even test it for you. Still be cheaper then buying new.
Old 05-12-2018, 05:14 PM
H-2 CHARLIE's Avatar
H-2 CHARLIE
H-2 CHARLIE is offline
would you run 18 year oil
Even water has an expiration date I would think the cleaning additives wood dissolve like soap going weak
Old 05-12-2018, 08:51 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Ask the manufacturer. I spoke with powerservice about the diesel additive I use from them. They said try to use it within a year of opening and if sealed it was good almost indefinitely. I was asking since the winter stuff was on sale locally last spring. After speaking to them I stocked up.
Not saying they are the same but you may be surprised.
Old 05-12-2018, 08:52 PM
dn29626's Avatar
dn29626
dn29626 is offline
Originally Posted by Bonanza35
...Blackstone...
Send a sample to test.
Old 05-12-2018, 08:56 PM
z31freakify
Ill order a Test kit on Monday and send it out ASAP im just curios as to what Blackstone scientist will say.
Old 05-12-2018, 09:04 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Me too plus some more to make 10 characters or more..
Old 05-12-2018, 09:05 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Originally Posted by H-2 CHARLIE
Even water has an expiration date I would think the cleaning additives would dissolve like soap going weak
A lot of that is just complete BS, there is an expiration for salt - even though it's already millions of years old, for some reason in a year or two it'll be past the "best by" date lol
Old 05-12-2018, 11:44 PM
H-2 CHARLIE
I believe that once oil has a few cycles on it the carbon effect takes over from there on the age .
So even a few cycles on burnt oil the time is ticking .
Old 05-13-2018, 05:48 AM
Walleye Hunter
Excellent point on salt there and my bet on an expiration date would be the FDA. They seem to need an expiration date on everything we consume.
Quick Reply: Would you run 18 year old oil?
