2000 Factory AC Fan Issues
Old May 11, 2018 | 03:47 PM
Texas Mad Man's Avatar
Texas Mad Man
As the title says, the problem started a couple of months ago. I have a 6 cylinder E150 with front and rear air. I do not use the rear since the van is partitioned off.
Front AC fan works fine just cruising around but when the accelerator is pushed down to speed up, the AC motor cuts off. Air comes back when I let off the gas.
Would this indicate a vacuum problem of some sort?
Has anyone ever run into this before? Thanks
Old May 12, 2018 | 08:56 AM
JWA's Avatar
JWA
So the blower motor stops completely, no air from the vents at all? This shouldn't be the case but a vacuum leak somewhere between the source near the throttle body and the function control switch (A/C, Max A/C, Vent, Heat, Defrost etc) can and does cause air flow to change from vents or floor to full defrost. returning to the selected function once vacuum has "caught up".
Old May 12, 2018 | 09:35 PM
Im50fast's Avatar
Im50fast
Sounds like a classic case of failed check valve/vacuum canister.
Im very surprised that JWA is suggesting otherwise.
Ive had two Ford vans with this exact thing. Never fixed either one lol.
Bill Wiggins
Jun 28, 2017 08:11 PM
hairyboxnoogle
Dec 5, 2010 03:46 PM
891/2ton
Electrical Systems/Wiring
Aug 19, 2007 02:14 PM
oldmanbergie
Aerostar
Apr 18, 2006 11:57 AM
dg714
Aerostar
Aug 3, 2003 07:15 AM
