1996 4.9 L starting problem
Old May 11, 2018 | 12:16 PM
misswild's Avatar
misswild
I have a 1996 F-150 4.9L Eddie Bauer ed. that has a problem starting in hot weather. When the outside temperature is above 85 degrees F my truck has a hard time starting. When it does crank it feels like it is only hitting on a couple of cylinders, but after awhile it straightens out and runs great. This only happens when the outside temperature is above 85 degrees and doesn't matter whether the engine is hot or cold. Anyone know what may be the problem as my mechanic can't get it to mess up on him. I replaced the ignition coil next to the distributor and doesn't seem as bad, but still happens during the summer months.
Old May 11, 2018 | 01:16 PM
jas88's Avatar
jas88
You should replace the pickup coil in the distributor.
Old May 11, 2018 | 01:29 PM
misswild's Avatar
misswild
Thanks for the info will see if that works. Not much working on these newer trucks and need all the help I can get.
brokeasajoke
19
Aug 20, 2016 08:00 PM
badkins50
Apr 18, 2011 06:34 AM
bushwick56
Nov 4, 2007 12:12 AM
Mr.JP
Jul 23, 2004 12:47 PM
FlaresideGlenn
Electrical Systems/Wiring
May 14, 2003 03:14 PM
