1966 - 1977 Early Broncos
c4 swap in69
Old May 11, 2018 | 09:31 AM
big oak's Avatar
big oak
c4 swap in69
well i am in need of parts for my 69 c4 swap namely a good c4 i am in alabama
Old May 12, 2018 | 09:05 AM
chrlsful's Avatar
chrlsful
I have 1...some 1 stole my tq converter, TV cable and pan.
It's frm a 77bronk (302).
If interested I havea dyn-o-mite shipper.
Best to go w/my email (in below sig) as this is not the "For Sale" forum.
Old May 24, 2018 | 09:51 PM
dodmort's Avatar
dodmort
I am not having much luck finding one for my 68 either. ( at a decent price) I have a 435 in good shape a Ran in it now which makes some odd sounds when shifting sometime 2 RAT trans layin around... really want a c-4....
Old May 24, 2018 | 09:58 PM
chrlsful's Avatar
chrlsful
year/make/model
Modified C4s remain popular with hot rodders and drag racers due to their simplicity and durability.
Year & Model breakdown:
  • 1964–1966 Select Shift, 24/24 spline, castings: C4, C5, C6
  • 1967–1969 Select Shift, 24/24 spline, castings: C7, C8, C9
  • 1970–1970 Select Shift, 26/26 spline, castings: D0
  • 1971–1979 Select Shift, 26/24 spline, castings: D1, D2, D3, D4, D5, D6, D7, D8, D9
  • Applications:
Old Jun 10, 2018 | 05:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Besides a good C-4 trans (preferably from a 66-77 Bronco) you will need a auto transmission flywheel, engine plate, auto trans starter, a auto trans to Dana 20 xfer case adapter. The standard transmission to Dana 20 xfer adapter case will not work. Different stub shaft. A trans kick down lever, auto steering column or get a floor shifter. Wire in a safety neutral start switch. Decide if you want to swap pedal assemblies or just drop the clutch pedal to the floor or tab weld both the brake and clutch pedal together.
https://www.tomsbroncoparts.com/prod...SABEgL-kPD_BwE
50-4200 : Ford C4 3 speed automatic transmission to the 1966-77 Bronco Dana 20 transfer case, adapter kit. Advance Adapters
https://www.wildhorses4x4.com/produc...ssion_Adapters
https://www.dufftuff.com/Adapter_C4_..._20_p/3510.htm
I am in the middle of gathering parts for this exact swap.
chamblizi
13
Jul 20, 2012 08:25 AM
joe cowan
Jan 1, 2010 07:10 PM
graymule
Feb 8, 2009 06:39 PM
wintremute
Aug 28, 2006 11:02 AM
