460 Valve train question?
Old May 10, 2018 | 07:18 AM
Jpegg01's Avatar
Jpegg01
I have a 460 I was told came out of 74 Ford RV and am refreshing top end before dropping in truck as my current 460 engine threw 2 rods. My question is I want to replace the push rods and lifters but wanted to know is the push rods and lifters different from a RV 460? I was told RV 460 had bigger cam and I dont know how to tell?
The push rods appear to be same length as my blown 460 however I dont know where that engine came from either. So how do I know what cam I have so that I can get correct parts?
Thanks!!
Old May 10, 2018 | 01:14 PM
mark a.'s Avatar
mark a.
Why do you want to replace the lifters ? If you do replace them you should check lifter preload, then you will know if you need different push rods.
Old May 10, 2018 | 01:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I was told RV 460 had bigger cam.
1968/90: There is only one 460 camshaft.
C8SZ-6250-A .. Camshaft / Obsolete
1968/73 Ford/Merc Passenger Car 429 except CJ & S/CJ / 1968/78 Lincoln/Continental Mark III/IV/V 460 / 1973/78 Ford/Merc Passenger Car 460 / 1973/79 F100/350 460.
1974/76 M450/500 (M series Class A motor homes) / 1975/90 E250/350 460 / 1983/90 F250/350 460.
No 460's in cars after 1978, in F100 after 1976, in F150 after 1979. 460 not available in 1980/82 F250/350, reintroduced in 1983.
Old May 10, 2018 | 03:02 PM
Jpegg01's Avatar
Jpegg01
Engine has been setting in garage, I just figured it would be good idea to replace them as they aren't very expensive
Old May 20, 2018 | 07:56 AM
Jpegg01's Avatar
Jpegg01
So, could someone clarify for. I hear "RV" cam talked about a lot on here I assumed getting a 460 out of an RV would come with the "RV" cam. Is that not the case?
Old May 20, 2018 | 12:31 PM
matthewq4b's Avatar
matthewq4b
RV cams refer to after market cams that are aimed more for low end torque and pulling power rather than high end rpm
Old May 20, 2018 | 12:36 PM
NumberDummy
How much more clarifying do you need? As I stated, there is ONE Ford 460 cam from 1968 thru 1990.
Crabby144
Jul 18, 2007 07:50 PM
kenjan61
Sep 28, 2005 03:38 PM
cockypolly
May 12, 2005 04:38 PM
f250rangerexplorer
Dec 5, 2004 11:02 PM
78bigunns
Jun 3, 2002 12:16 AM
