460 passenger car or 460 truck engine any differences?
Old May 31, 2002 | 11:32 AM
78bigunns's Avatar
78bigunns
Old Jun 2, 2002 | 09:18 PM
78f250lj's Avatar
78f250lj
460 out of a 1986 f350 truck, can anyone tell me if there are any internal differences between this engine and a 460 out of a passenger car and would a 460 orginally out of a truck be more desireable for any reason for a truck swap?
Old Jun 2, 2002 | 10:00 PM
tellico racing's Avatar
tellico racing
only differences would be the oilpan and oilpump pickup i would use all the original brackets from the vehicle recieving the engine. hope this helps
Old Jun 2, 2002 | 10:42 PM
wrangler76's Avatar
wrangler76
I've got a low milage 460/C-6 out of an '86 E-350 ambulance I could part with if motivated by monitary offers...
Old Jun 2, 2002 | 11:05 PM
jsworkman's Avatar
jsworkman
the dip stick on a car engine is located in the block on the front of th engine the dip stick on a truck engine is located in the oil pan if you can get the engine from a van as posted this would help the van has a rear sump pan which you need to install into a truck the van exhuast should clear the frame rails you may not need the headers from L&L or Headman but I would use the motor mounts I did this swap in my 76 crew and the mounts are money well spent
John Workman
76 F250 Crew Cab Short bed
460 / C6
Old Jun 3, 2002 | 12:16 AM
masterbeavis's Avatar
masterbeavis
Yes. '79 and up are externally balanced
>and would a 460 orginally out of a truck be more desireable for any >reason for a truck swap?
No. The only advantage to using a passenger car motor is if you grab a Pre '72. They boast 365Hp, 500# torque, where the later 460s have about 265hp?? The trucks usually do have better connecting rods though. They can be idenified by having football shaped heads, NOT square ones.
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
GeneGregory
Jan 17, 2017 11:40 AM
bsneed
Dec 28, 2016 01:29 PM
junkyardjeff
Dec 12, 2016 09:13 PM
pinkhorse
Jul 1, 2004 08:56 AM
brett_d
32
Sep 10, 2003 09:04 AM
