460 trans problems
Old May 9, 2018 | 12:02 PM
Molson003's Avatar
Molson003
460 trans problems
I have a 460 with a automatic trans but I am converting it to a manual. I bought a np435 but the input shaft is to long. I am hoping somebody has a solution.
Old May 9, 2018 | 04:49 PM
PA74F250's Avatar
PA74F250
460 only came with auto so you'll have to do a little rigging to make it work. It's been discussed a lot if you search it.
You can use 390 184 tooth flywheel, 302 pilot bushing and your starter.
Old May 9, 2018 | 09:07 PM
Molson003's Avatar
Molson003
460 trans problems
the splines are where the bearing is suppose to be
Old May 10, 2018 | 07:45 AM
fordrealdrive's Avatar
fordrealdrive
What is the input shaft size (diameter) & spline count? What did the np 435 come out of originally?
Old May 14, 2018 | 06:33 PM
Molson003's Avatar
Molson003
I think it was on a six cylinder the splines are 10. The size where the bearing rides is -.670 and the size of the splines is 1.8
Old May 16, 2018 | 06:43 AM
Molson003's Avatar
Molson003
460 trans problem.
I think it was on a six cylinder the splines are 10. The size where the bearing rides is -.670 and the size of the splines is 1.8. I am having trouble finding this problem anywhere.
Old May 16, 2018 | 07:41 AM
fordrealdrive
Ford lightduty (F100-F350) np435's use a 1-1/16" diameter input shaft with 10 splines & sticks out 6.5" from the face of trans housing.
Old May 16, 2018 | 11:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I-6 or V8 makes no difference.
C4TZ-7017-A .. NP435 Input Shaft .. 17 helical teeth, 21 clutch teeth, 10 splines, 9 3/8" long: 1964/79 F500/750.
C5TZ-7017-C .. NP435 Input Shaft .. 10 1/16" long: 1965/77 F100/350.
D7TZ-7017-C .. NP435 Input Shaft .. 17 helical teeth, 24 clutch teeth, 10 splines, 9.00" long: 1977/79 F100/350 & 1978/79 Bronco.
Old May 19, 2018 | 10:10 PM
Molson003's Avatar
Molson003
Ok so so that’s what I have but what do I do to make it fit.
Old May 20, 2018 | 10:35 AM
fordrealdrive
What is it that you have?...the measurements you posted, the measurements I posted, or 1 of the 3 input shafts that number dummy posted?
Was, what you think is a six Cylinder an I or V6 ? Was it even a Ford 6 cylinder or maybe a dodge or a chevrolet ?
Did your NP435 come from a Ford, dodge, chevy, an old bread delivery truck, maybe it came from an industrial aircraft tugger??? I have no idea!
Point I'm trying to make, is that the NP435 comes in many configurations & applications.
Old May 21, 2018 | 12:14 PM
Molson003's Avatar
Molson003
I was told it was from a small block ford. That’s all I know but it measures up the same as the straight six ford it’s the 1-1/6 one. 10 spline
Old Jun 1, 2018 | 08:13 AM
Molson003's Avatar
Molson003
460 trans problems
Lds79ford
WTB - Parts & other
Feb 22, 2017 09:31 AM
NP435Bronco
32
Apr 21, 2012 11:42 PM
78ford1ton
Engine Swaps
Jul 16, 2010 06:35 PM
thetinman751
Mar 20, 2009 03:09 PM
b bell
Aug 13, 2004 01:39 PM
