LARIAT ultimate questions
Old May 9, 2018 | 09:27 AM
98woody's Avatar
98woody
I have a couple questions on an 18 lariat ultimate:
1) the led side mirror spot lights, is there an over ride component to turn them on wheel the vehicle is in motion? For instance parking against a wall it's nice to have the light. There's no need for them on parked.
2) is there a parking light only option on the LED headlight system without the daytime running halo?
3) I thought the lariat ultimate came with 4g Wi-Fi hot spot? Is there and how do I locate it to connect?
Old May 9, 2018 | 09:44 AM
mhoefer's Avatar
mhoefer
When your moving slow but in reverse or drive the spot lights can be on, over 10 mph they turn off.
with Forscan software you can change the DRL marker light setup to your preference.
you have to have the modem installed, don’t know for sure it’s on the 18 Lariat ultimate, check your build sheet.
Old May 9, 2018 | 10:18 AM
98woody's Avatar
98woody
What modem?
Old May 9, 2018 | 11:34 AM
Robeleo's Avatar
Robeleo
Number 1 can be done to work at any time and speed but it's a hardware modification in the module
Old May 9, 2018 | 12:03 PM
98woody's Avatar
98woody
Can I get directions? Where is the module? I'm ok with unplugging a wire but what do I solder???
Old May 9, 2018 | 12:15 PM
Robeleo's Avatar
Robeleo
Successfully performed the LED mirror spotlight mod on my F-350 truck. Removed and shrink wrapped grey wire with orange stripe #2 from the connector. Then I soldered pins 1 & 2 from the underside of the spotlight module. Works great and allows me to be able to use the spotlights anytime to include while driving. Factory defaults the spotlights to turn off after approximately 10mph.
It's not my post and I haven't tried, so don't blame me for any issues. By the comments in the post this really work and even work with the truck off
S cobb
May 24, 2018 12:10 PM
kla94
21
Jan 25, 2017 09:57 PM
cameeks
Mar 16, 2013 11:20 PM
xc4jokestomper
45
Oct 22, 2010 06:34 PM
caprang
Feb 22, 2010 10:38 PM
