74' F100
Old May 7, 2018 | 04:56 PM
russhenry715's Avatar
russhenry715
74' F100
I am looking to upgrade my truck brakes from drums to disk breaks. Are there any suggestions on the proper way of doing them? I appreciate all suggestions
Old May 7, 2018 | 05:02 PM
Tedster9's Avatar
Tedster9
I thought F100 got discs in '73, I'll take your word for it though.
Old May 7, 2018 | 09:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Tedster9
I thought F100 2WD got discs in '73.
Beginning 1973 F100 2WD = Manual disc brakes were standard equipment, power disc brakes were optional
Front disc brakes were not available for F100/250 4WD until 1976.
Old May 8, 2018 | 05:08 AM
benbuilder's Avatar
benbuilder
disc
I have a pair of both 2 wheel and 4 wheel drive spindles id interested email me at chircolandinc@gmail.com
Old May 8, 2018 | 07:36 AM
monkey-1's Avatar
monkey-1
I also have a set of front disc brakes off of my 1977 with the bog bolt pattern, and some from a 1981 with the small bolt pattern.
Old May 8, 2018 | 09:18 AM
russhenry715
Thanks i guess i forgot to mention it was 4WD. I just purchased the truck from my wife grandfather and it runs good but all the break lines are cracked
Old May 8, 2018 | 10:59 AM
gittinwidit's Avatar
gittinwidit
About any front dana 44 axle with disks from any make will swap as long as you swap everything from knuckles out. This includes the 3/4 ton 8 lug d44's as well. But only in the straight axle variety. The independent 4wd D44's have different angles for the knuckles. But you can even swap Chevrolet or Dodge everything from knuckles out if that was what you found. This swap is common and can even be found brand new now.
Old May 8, 2018 | 04:25 PM
HIO Silver's Avatar
HIO Silver
Concur.. knuckles and spindles outwards. You'll also need disc/drum MC and proportioning valve.
INFAMOUS_RED460
May 14, 2014 08:41 PM
big-papa
Feb 15, 2012 01:57 AM
ford rangers
May 15, 2011 12:35 PM
thesprocket26
Aug 14, 2004 09:22 PM
avery
Jul 7, 2003 05:23 AM
