There is nothing to reset for the TPS (Throttle Position Sensor). The PCM checks its position every time when you start the engine and it scales the readings from there.
This assumes, of course, that the TPS is properly installed and is not defective or incorrect for the application.
In my defense: Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a toatl mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
