Overcharging problem?
Old May 6, 2018 | 04:47 PM
fordf348's Avatar
fordf348
While out on a ride today of approximately 100 miles I noticed my battery gauge needle was showing a charging rate higher than ever, all the way over to the right. Last year I had my generator rebuilt not because of a problem but I just felt every 25 years or so it needs to be rebuilt. When I stop at a light the needle comes back to just slightly above the center where it always rests. Any ideas or suggestions as to what to check? I am still 6 volt positive ground.
Thanks
Ed
near Philadelphia
Old May 6, 2018 | 05:05 PM
raytasch's Avatar
raytasch
Believe Nothing
Ed, you need to check static condition, voltage of the battery. Then check voltage when the engine is running above idle and the ampmeter is showing "high".Post these voltages. Excessive charge rate would be the norm for an old battery on its way out. My swag is what you are seeing is normal unless the battery is "boiling". Worst case is bad regulator.
Old May 7, 2018 | 06:55 PM
fordf348's Avatar
fordf348
Ray, looks like about 6.5 volts just sitting and about 9.5 above idle, also the gauge seems to be operating like normal again
Ed
Old May 7, 2018 | 07:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Either the battery is shorted or the regulator is stuck. Is the battery draining overnight?
Old May 7, 2018 | 09:09 PM
fordf348's Avatar
fordf348
I thought the numbers looked pretty good for a 6 volt positive ground system?
Old May 7, 2018 | 09:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Regulator should be limiting voltage to 7.2 to 7.6 volts above 1500 RPM.
Old May 7, 2018 | 10:19 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
One of my old cars did this on a trip when the voltage regulator did not register the correct battery voltage and told the generator to charge as much as possible. The result was that the battery started to smell as it boiled itself away. A quick fix was to remove the voltage regulator cover and insert a match book cover between the contact points. Replacing the regulator when I got home fixed the issue,
Old May 8, 2018 | 04:34 AM
fordf348's Avatar
fordf348
Sounds like I need a new voltage regulator. Thanks for the help
Old May 9, 2018 | 01:13 PM
fordf348's Avatar
fordf348
OK, I installed new voltage regulator......now have about 6.5 volts static and about 7.5 volts above idle
Thanks for the help
Ed
Old May 9, 2018 | 01:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The old one may be able to be adjusted or the contacts cleaned, don't toss it.
Old May 9, 2018 | 03:10 PM
fordf348's Avatar
fordf348
I did open the old one and it looked brand new inside, it is about 12 years old.
Ed
choate
23
Aug 10, 2016 01:26 PM
tabijan
Jan 16, 2013 09:44 AM
mediaman67
Mar 7, 2010 07:37 PM
Jack01
Sep 22, 2003 07:31 PM
Aekisu
Electrical Systems/Wiring
Jul 29, 2003 05:20 AM
