Battery gauge way low
What's up everyone. Haven't posted in a while which has meant no issues w the truck lol. Well today the battery gauge continued to go lower and lower. I had the batt, alt and starter checked. The diagnostic tool said the batt need replaced even thought it read like 12.8 volts. What's weird is the batt indicator on the dash continued to go down which to me would indicate a problem with the alt (charging). Battery is from 09 so I'm gonna replace that and see if it helps but is it possible the gauge connection itself is bad or something?
Well.. who and how did they check the battery?
12.8 is good ... IF that is the open circuit "resting" voltage, that is, after any surface charge is removed. That's why it COULD be a defective battery if that is measured right after a drive or charging.
It could also be defective, even if it measures OK and that is an accurate voltage. The conductance type testers are good at weeding these types of failures out.
Typically in a healthy charging system, if one were to measure a battery after a moderate drive (or after charging) it will show an elevated voltage, this isn't the "true" battery voltage. One way to get the actual voltage is wait overnight, say 12 hours or so.
Another is to turn the headlights on (engine OFF) for about 5 minutes or so, then wait for at least 10 minutes. The voltage will "bounce back" to an accurate measurement. What I'm getting at, is 12.8 volts at the battery after a healthy drive isn't good and would indicate a problem. Voltage measurement is an accurate way to determine battery health, actually "state of charge", because a bad battery will usually either stop accepting a charge and/or stop holding one.
Be sure to charge up your new battery as well btw. Brand new batteries are "hard" in terms of accepting a charge and will not reach their full capacity until after several starts. The last new battery I bought took several hours to reach 100%, your alternator will thank you, and this will help ensure maximum battery life too.
The truck sputtered when I pulled into my drive. It died but started again and I put it in the garage. Gonna have someone that knows what they are doing look. Some swanky stuff going on electrical wise. Got an ABS light right before I shut it off and it was sputtering getting into the garage
I thought you did that already, from your original post. Again who, and how, did they test it?
If they said it's bad after testing, I wouldn't doubt them, considering you're seeing these other related symptoms. But it's super simple and easy to perform your own diagnostics a digital voltmeter can tell practically everything required.
Last edited by choate; 07-17-2016 at 07:14 AM. Reason: Added the name of shop and how they tested
One aspect that is sometimes overlooked, as mentioned earlier, run a voltage drop test on the individual battery cables and grounding points and alternator hardware. It's simple, quick and easy, and no disconnecting anything. It's based on the fact that electricity likes to take the easy path.
So if we put a voltmeter in parallel with a wire, or connection, while under load, the voltage drop in that circuit will be displayed as a positive voltage on your DVM. Since an alternator and other high current components will be crippled with ohms resistance practically too small to measure, they are always tested under load, for voltage drop.
Just a few hundredths of an ohm resistance anywhere in the circuit will reduce alternator output by 1/3rd. Maybe not enough to notice at idle, but apply any sort of load, and it will not be able to keep up.
Because of this phenomenon I bet a lot of alternators are replaced unnecessarily. It's not that bigger alternators ain't better but it makes more sense to get the performance we already paid for, instead of heating up wire and spending even more on replacement alternators. Worth checking out anyway.
