Any idea what engine is it?
Old May 6, 2018 | 02:43 PM
ISFord's Avatar
ISFord
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 6, 2018 | 05:57 PM
85e150's Avatar
85e150
Welcome to FTE.
Trapazoid valve covers with six bolts: SBF
No space between the water pump mounting and the deck: 221/255/260/289/302
"E5AE" on the manifold, carb manifold (maybe, could be CFI, and the more I look for images, that's probably it), EGR, thermactor plumbing: 1985 or later 302, unsure as some used CFI, some in '85 had carbs.
What are you going to do with it?
Old May 6, 2018 | 06:10 PM
Conanski's Avatar
Conanski
That is an '85 spec 302, nothing special as it is but it could be a solid motor after a rebuild.
Old May 7, 2018 | 01:51 PM
ISFord's Avatar
ISFord
Seems like you guys are right but I understood that this block is light and won't carry more then 300-350 HPs :\
Old May 8, 2018 | 09:21 PM
baddad457's Avatar
baddad457
What are the engineering numbers on the block ? They're on the bottom rear of the block.
78Hayride
Apr 7, 2019 09:43 PM
Dobies4life
Mar 10, 2014 10:39 PM
pauli3wood
37
Jul 9, 2013 04:03 PM
Talyn
20
Jan 9, 2010 01:01 PM
